Anyone know of a finish that applies OVER wax?
Steven Antonucci
Steve antonucci
>I have a unique situation where wax is applied first and I anm looking to apply a protective coat over it. Any ideas?
Steve
Re: Anyone know of a finish that applies OVER wax?
Ron in Drums PA
>Remove the wax with mineral spirits first?
Barbara Gill, Remlik VA
>The only one I know of is for a floor application. DuraSeal Penetrating oil finish is followed by the same company wax (solid) that is buffed on. A product called DuraSeal Renovator will mix the old wax with dirt, etc. and leave a fresh finish. This is called an oil/wax finish. It could be used on an item not intended for food use. I don't know if it is food safe but I doubt it.
More wax. ;)
Carole Valentine
Shellac ?
Don Orr
>I agree with Ron. I don't know of a finish for sure that will go over wax but mineral spirits has removed any wax I needed to get off without damaging anything.
Steven Antonucci
The uniqueness prevents removing the wax...
Steve antonucci
>I am experimenting with a "new" (to me) technique, and I need the existing wax to be preserved for this technique to be useful. I have a B-plan idea if there is not a wax based answer, but the wax solution is much more economical and accessible.
Steven
Re: The uniqueness prevents removing the wax... *LINK*
Jeff Morneault in northern Maine
>I've never used this product but seems to do what you are wanting to do??
Fiddes Protex
mjonesrdg
>Steve,
Gilder's paste, or sometimes called Gilder's Wax is often over- coated with a variety of products. Krylon is mentioned in an article I recently read, and Gourd painters use spray lacquer and artists fixative. As always, try a scrap first.
Russ Fairfield
>I have no idea why you would want to preserve a layer of soft wax under a harder finish film. I would suggest that you state the problem, rather than your solution. That way we can offer viable alternatives.
The problem is that wax is at the bottom of the heap of finishes, and it is soluble in every solvent and thinner that is used for a finish, except water; and the waterbornes bead up when they are applied on top of a wax.
Since the wax is soluble in the thinners and solvents, it becomes a part of the finish, making it softer than it would be were it not there. Oils, lacquer, and shellac can be used over a coating of wax for the texture and "feel" that it imparts to the surface. It also makes the finish more flexible and it will not become as brittle with age, nor will it "yellow" as much as it would have without the wax.
Only if it's Wool Wax
Al Neighbors
>Wool Wax is used for smoothing previous coats of Nitrocellulose Lacquer finishes. The next coat of lacquer is applied without removing the previous coating of wool wax.
I've used it for years; and I think it's the only combination where a finish works with wax being applied first.
hope this helps.
Steven Antonucci
Simple: The wax contains something I cannot remove
Steve antonucci
>without altering the piece dramatically.
Ed Heuslein
>Steve, I have successfully used lacquer over Liming Was several times. After applying the Liming wax, I burnish the surface with 0000 steel wool then spray with Deft to seal everything in. I use just a couple light coats. I have a couple pieces that were done a couple years ago and no sign of separation. This was passed on to me by an old sage who knows a heck of a lot more than I do. Ed
Don's right. Shellac or ..>>
RonZ
>..>> friction polish will go over it depending on the situation. Then you can apply wax again or carnauba if it wasn't before.
Re: Simple: The wax contains something I cannot re
RonZ
>I knew it was top secret.
