A55 Smoothing Plane
Yet Another Idea To Add Movement *LINK*
charlie belden
>I've been playing with ways to add actual movement to turned pieces. The idea of 2D's Cell Animation - applied to an actual 3D object (actually SEVERAL 3D objects based on the same theme) popped into my head somehow and I've started playing with the idea.
Sorry about the GIF animation. The frame rate seems to change depending on the browser used. Hopefully it'll convey the idea.
Bubble Rising - Cell Animation Idea
Re: Yet Another Idea To Add Movement *LINK*
John Veerkamp, Western Mo
>Charlie,
Get a job. You're having way too much fun with animation. Next you'll be doing pieces for Spielberg.
My favorite animation idea is a "box" whose sole purpose is to turn itself off. Flip a switch, a hand comes out of the box and turns off thwe switch mand the hand withdraws.
Keep posting these ideas.
John
Bob Macgregor
>I think that sequence would be more realistic hanging the other way, like a mobile, ie, a dripping drop rather than a rising bubble. Does a rising/escaping bubble elongate like that?
Michael Mocho------WebKitFormBoundarylK40+DdFANqFE
>Hi Charlie,
What you are describing is known as a zoetrope, and is one of the earliest forms of animation. It�s been around since about 180 A.D.
Sequential images are placed on the interior of a cylinder (could be a bowl) with slots between them, and when rotated on the cylinder's axis and viewed from the outside looking through the slots (across the axis to the interior panel) the illusion of movement is seen. The more images, the smoother the illusion of motion.
Seems like the idea would work with presenting 3-D objects instead of 2-D images.
Check this out:
Zoetrope
Randy G
>To expand on the idea... what if you added the same segments in reverse to so that it wasn't a start and end, but a continual bounce.
charlie belden
>Zoetrope - interesting word - zoetropic turnings. There's a certain redundancy in the comibination.
The idea also harkens back to early high speed photography, which initially focused on common occurances. When played back at much slower speed, the images revealed the beauty and complexity of everyday events which couldn't be noticed at actual speed. A nice metaphor. How much of our day to day life overlooks some pretty incredible things that occur at speeds faster or slower than we can perceive - a humming bird's wings, or a hill or mountain eroding. Maybe that's some of what hallucinogens do, change one's rate of visual perception.
Back to how a bubble behaves - I was working from memory - of a high speed movie of a drop of milk as it falls into a pool of milk. If you search YouTube I'll bet you'd find a video of that one - in both directions - falling, then a dropplet bouncing up out of the center of the splash.
Yes, the sequence could be made an infinite loop, ended back where it began - and repeating over and over again. That might work better since there would be a continuim (sp?) which could lead to a better understanding of what's being seen. On the other hand, that could also kick in the analytical, objective, pattern recognition part of your experience - and destroy the child like Oh Look! sense of delight of the experience.
Re: The need to "get a job" implies one of the greatest barriers to "creativity" - a Puritan "work ethic" - "nose to the grindstone" - if you're not producing / working - you must be sinning. The overall Puritan view seems to be a terrible fear that "somewhere, someone is having fun - and not being punished for it."
It's hard to see, let alone appreciate, the interesting things going on around you - when you're nose is on the grind stone.
I'm very lucky to have left that "40 hour a week treadmill" (though my typical work week was more like 50 plus hours and semi-often 60 and 70 hours) at age 55, now 8 years ago. Having spent so much time "under the gun" and in that "pressure cooker" environment - it's no surprise that so many odd/ unusual ideas started bubbling out. Sometimes it's more like popcorn - kernals going off and flying all over hell. Thinking about popcorn - who would guess that there were interesting white shapes contained in each kernal of corn?
The Adams Family Lurch (I think the hand that came out of the box was named Lurch) idea could be applied to a lidded box with a little thought. A slowly rotating cam pushing a rod attached to the top of the inside of the lid, a small battery powered motor - with a spiral gear on the shaft turning a regular gear attached to the cam, . . . Voice Activated - of course. A hand clap and the lid would slowly rise - and just when you can begin to see inside the box - it "snaps" shut.
Another Micro-Bot idea to look into! (Illustrations to be made to work out some
details - another puzzle to play with!)
THANKS! (I think). I'll post Progress Reports.
This idea is a good example of synthesis - take two very old ideas and combine them in a new - at least to me - way to come up with something that has characteristics of both - but "new". (I'm sorry to keep using "synthesis" rather than "creative" but the distinction is important to my getting around the "I'm just not very creative" mental block).
Yes, the sequence done with a "droplet" of a liquid falling from above would work just as well as a bubble rising.
Bob Macgregor
>I think that idea would work if you mounted the sequence on a carousel or mobile and spun it...it would undulate like a sine wave or bouncing ball.
BOB
Bob Macgregor
>I think Lurch was the butler, Thing was the hand in the box.
I have seen a coin bank that works on those principles; place a coin on it and a hand reaches out from under a trap door and drags the coin back into the box. It always kind of reminded me of a trap-door spider.
BOB
