$30 hollowing 2nd pic
Dick Coers
Re: $30 hollowing 2nd pic
Brad Vietje
Brad Vietje
>Excellent idea, Dick. I suggest re-working the cutting tip arrangement for getting into smaller openings, but generally a really neat idea.
Safe spinning,
Brad Vietje
Newbury, VT
Very interesting!
David Walser
>Dick,
One of the things I like about your version of an articulated hollowing tool is how compact it is. Many of the commercial versions seem to require a lot of room between the articulated arm and the blank you're hollowing. For those of us with short-bed lathes, this can be very limiting.
bernie feinerman
>Did you drill out the 1/2" iron "T" fittings while they were on the lathe, or use a drill press?
How much range of motion does your present system have? 6", or more?
Dick Coers
>I bored out 3 of the tees on a metal lathe, 2 or them on a drill press. One of my tests on this rig is to see if almost anyone could build one. So I use a metal lathe on 3/5 if it, a drill press and disc sander on the other 2/5. I think I mentioned that doing that on the drill press was really dicey. To be honest, I just about broke a finger. I changed my method and used a large wood parallel wood clamp instead of the small drill press vise. Worked much better.
By using a 2" pipe, a 4" pipe, and the tees, I have 9" from the center of the pivot to the end of the adapter. So by theory, it will almost hollow an 18" vessel. I still haven't turned a vessel to finish, so I don't know if that is enough movement to the side for getting under the top.
GalenV in Iowa
>Dick
I'm still working on a smaller 3/8" tee version and 5/8" bolts when I got time. No metal lathe so set up the five tees and turned them on my Jet 1220. Took a bit of time to make a boring bar adaptation to open up the tees for the bolts. Never should have sold my metal lathe!
Yah, I tried the drill press but sure enough no matter how slow I feed it did catch. Now I know why I need a safety shut off for my drill press! Sure played heck with my necked down drill bit. I don't remember why I necked a 5/8" drill bit down to 3/8" but nice bend in it now. Will be a cost overrun if I figure the bit agains your $30!
I have to come up with a better base to bed mounting as my first version is sloppy. Think I can use my current square hollowing bar as it mounts in a 3/8 pipe handle anyway.
By the time I am done you will probalby have your version 2.0 out.
Galen
