$30 articulated hollowing tool
Dick Coers
>$30 if we don't count the boring bar. I wanted to make some improvements to my previous homemade system I had made for hollowing, so I decided to start from scratch. I was ready for a store bought one, even the wife was on board. But, the dollars just seemed to be too much of a hurdle. Besides, I love to invent. So here is my system. I used standard 1/2" black pipe and tees. The tees require the most work. I bored them out to 3/4", and faced off the mating surfaces. I know many don't have access to a metal lathe, so I tried a couple on the disc sander. Almost the same, but that pair does have a very slight high spot when I rotate 360 degrees on that link. When boring the tees to 3/4", a little of the thread is left in the bore. If this doesn't work out, I will probably add some flanged bronze busings and bar stock for the pivot. The standard 3/4" bolts aren't close enough to .75 diameter, but the fit isn't really bad. I used 2" and 4" long pipe, which allows the sections to rotate 360. I have another link of 6" pipe ready if I need the reach. I also added UHMW washers between the tees as a slight buffer for out of flat tees and to see if the friction would be reduced. I suspect a little grease on the steel to steel face would work almost as well.
The first cuts are very promising. I have to take a little out of the plywood lathe mount, I'm a little above center. I snugged up the lock nuts on the 3/4" bolts as well. I found I can run them a little tighter with the mechanical advantage of the bar. The is just a little vibration in the cut, but I was cutting dry buckeye. I'll reserve judgement till I cut some wet maple. It looks really good so far.
If I had a photo tent, I would show the hollow work I am doing. That will come latter. Ask away if you have questions.
Re: $30 articulated hollowing tool
Wonderful Dick
Neat Idea!!
Gil Jones
GalenV in Iowa
>Dick
Very cool idea!
Just needs a paint job to match your lathe! :>)
Twenty questions:
1. Is the adapter to your hollowing bar a commercial steel coupling so it threads on the pipe section and bored to fit the bar?
2. The 3/4 bolts look to have nylon lock nuts to preset the slack in the connection. Right?
3. To turn the tee did you thread a pipe into one end of run to chuck it and turn the other end face and collar. Then use the outside turned collar when you turned it around to face and bore?
4. Is there a big washer on the bottom of your wood riser block as well as you have on the top?
5. With the wood adapter do you have much flex? I already have a similar wood adapter that I made to turn a sphere but never ended up finishing it.
6. No need for washers at bolt head and nut?
7. Would you think a downsize to 3/8" tees for a small Jet 1220 be too light?
Well not twenty questions but if you don't mind I would try a similar rig.
8. Do I worry about your patented design?
9. Slim budget for me to pay you royalties!!!
Galen
Dick Coers
>1.That is an adapter that I made. I thought about using a standard coupling that could be bored out to 3/4", but I thought the wall thickness might be too thin for set screws, and I also thought the coupling would be too short.
2.Yup, nylon ring lock nuts.
3.I probably should have done your method, but I chucked one end, using the tailstock into the threaded hole for alignment. I then turned the outside dia, and faced off the end. I flipped the tee and turned the od and face. Then I bored it out. On the pair that I tried the disc sander, I used paralled wood clamp to hold the elbow on the drill press table, then sanded the faces. I left the od rough. Boring on the drill press made me very nervous. A 3/4 drill can catch so easily.
4. Yup, something I had laying around. I thought I would screw it down to the plywood, but didn't. I think a standard washer would be okay.
5. I used a laminated veneer beam I had. It was around 2" thick and really rigid. I used two 1/4 all thread to stack all the parts and did not glue. So far it looks like it will be fine since most of the load goes to the tool rest, and the base just has to resist the torque and some lift.
6.The head of the bolt and nut are about the same as the diameter
of the tee. Wouldn't have gained any surface area with the washer.
7. My main concern of using 3/8 would be the reduced diameter of the tee faces. Since my bolts are a little loose, I use the faces to reduce clearances. 3/8 would work better for height though. Right now my rig measures 6" from the center of the boring bar to the face of the bottom tee.
Help yourself to the ideas, LOL. I've only got about 10 minutes of turning time so far. No promises on long term success. Good luck!
Not Because I actually Know Anything
Barbara Gill, Remlik VA
>about making this stuff but instead of the grease you said you would use, how about rubbing a piece of wax on those metal surfaces to get less friction.
That is what I do with the Jamison metal surfaces (not articulated of course and certainly not my idea). It seems as if grease was used , dust would stick.
Re: Not Because I actually Know Anything
Don Evans
>I agree with you Barb, microcrystaline wax, one of the dry coat waxes or even beeswax. All would work well.
Don
>I have found beeswax to be sort of sticky; in face it is one of the ingredients in the homemade belt dressing that I make per Stephen Shepherd's instructions. Lyle Jamison suggests using paraffin wax as in a candle.
>I use candlewax to lubricate the bottom of my handplanes. It has to be replaced often. I think grease would be better for what he's doing, but of course really lousy for a handplane. :) I also use the candle for my homemade Jamieson rig.
Terry Quiram
>Well done! I need to stop by and test drive your rig.
GalenV in Iowa
>Dick
Thanks for all the extra info.
I should have looked at the standard fitting center to face (1 1/8") for 1/2" and found my 12" swing leaves no room for an anchor point above bed. 15/16" for 3/8" pipe though but I'll look at face like you say.
Gives me a reason to go shopping at Lowes plumbing section and see about other types or sizes of fittings. Might pay to look at brass if from machined blocks as they may cost more but only need bored for bolt.
Thanks again.
Galen
How to machine the tees - My idea was poor!
GalenV in Iowa
>Dick
Your method to machine the tees will work better than what I was thinking!
Chucked up a pipe nipple and spun on the tee to face. The cheap tees are bored out of line so far the outer end ran around in loops!
Gripping the tee end and helping center with the tailstock did work better!
Trying a down sized 3/8" to better fit my small lathe swing.
Found some nylon bushings that I may put in the tees and use a different bolt.
The brass tees they had where cast so without going out of town guess the machined brass tees may be next model.
Thanks for showing your rig. Now just need to finish mine.
Galen
