My Second favorite home made calipers.
>These are my second favorite home made calipers. (I took my favorite set to a demo I did and they ran away from home, they were the same, but smaller)
They are made of plastic about 3/16" thick. The pivot is a tee nut, because that is what I had in the drawer. Any bolt will work.
The two sides are identical and cut at the same time. The line on the handle is the closed position. You could scribe a scale on them if it suits you. When they are closed the handles line up with each other and this gives a very tactile fell to them. Your fingertips will tell you very quickly if the thickness changes, even very subtle bulges.
I also like the fact that you can reach in between the Plates on Cole jaws and check the thickness as you turn the outside and you can check the thickness of the bottom as you cut the chuck foot off.
The critical point here is that the distance between the pivot and the tips is the same as the handle length, thus the reading is the same on each end. If the jaws are open a 1/4" then the handles read a 1/4".
I find these very useful. They are easy to use one handed. I don't own a set of the figure 8 ones, but I have tried them and these are MUCH easier.
You could change the shape of the jaws and make them asymmetrical, bigger, smaller any way you want as long as the pivot stays equal distance from the two ends.
I made my pattern out of cardboard and tried them before making the actual set.
