New Shop Lights Now No Radio
Stuart Johnson
>I've installed 6 T8 florescence lights in the shop and now all I can get on the radio is static. The lights are on their own circuit and properly grounded. The radio is a good 20 plus years old. I have no idea if the problem is caused by the radio or the lights. Any ideas or suggestions?
I don't really care about listening to the radio but I do like some music in the shop. With an MP-3 full of stuff I like are there any good quality speakers that can be hooked to the MP-3?
Re: New Shop Lights Now No Radio
With new lights on, and radio playing "static",
gil jones...ga
>turn off the lights using their circuit breaker. If the radio then starts to operate normally, you may have answered your question.
Would be interesting to "hear" the result.
Gil
GolfSteve in Calgary
>I have a similar problem with my car radio, but not with a 20 year old ghetto blaster that I have in the shop.
If I have the car radio turned on and the fluorescent lights turned on, I get a lot of radio static - but only on the car radio. If I shut the lights off, the radio reception returns to normal.
Dunno why. Probaby cheap fluroescent lights cause interference that screw up a good car radio but do not screw up a cheap ghetto blaster.
? gremlins
Rob Wallace
Rob Wallace
>Stuart:
As suggested, turn on the radio and turn off the lights. If you get a clean signal from a range of stations throughout the dial, there is just too much stray Radio Frequency being generated by the light fixtures (probably electronic ballasts). Not much you can do other than to try to isolate the receiver on its own circuit, and perhaps install an in-line RF filter with the power cord to the radio. If you can borrow another (perhaps more 'modern'?) radio and see if it experiences the same interference when the lights are on, you will need to work around the existing noise, RF bypass all of your new light fixtures, or turn in the dark! You may simply need to get a better receiver with more selective tuning, or one that is capable of rejecting the "hash" signals that might be generated from the electronic ballasts that are now being sold with fluorescent fixtures.
Another question: Are you trying to receive AM or FM radio signals? AM signals will be more prone to RF interference than will FM signals. If you are trying to listen to FM, then installing an external (and better yet, directional) antenna will improve the signal strength, and potentially increase the signal getting to the tuner of the receiver with minimal interference. If you are using an external antenna, you can try to shield the receiver from direct RF interference from the lights by putting it into a grounded metal box (Faraday shield) and be sure the connections to the antenna, speakers, and power cord are all done properly. I have worked on many situations of RF interference at an FM broadcast station where I was a station engineer (college days), as well as many situations involving amateur (ham) radio stations being interfered with by faulty power lines, local transmitters, and other sources of interference.
The troubleshooting process involves first identifying the source of the interference; second, assessing the receiving apparatus and its ability to tolerate or reject unwanted signals and tune and amplify the desired signals; and third, maximize the opportunity for the receiver to "see" a good signal (good antenna, quality feed line, etc.) at its input, while rejecting the undesired signals from whatever frequencies. Sounds simple, but resolving the situation can be very difficult sometimes.
If you have a local friend who is a ham radio operator, you might ask this person to help resolve this situation. I have been licensed as a ham operator for 32 years and have seen my share of RF interference. Most RF interference situations can be resolved with some good detective work, deductive reasoning, and effective grounding and bypassing, but you need some basic electrical and radio knowledge to do this correctly and safely. Electricians can be consulted, but most don't want to deal with RF issues - they're more likely to operate on the basics of "pull the wires, hook it up, give it power, I gotta go...." and would prefer not to deal with this kind of problem. Some might, but most don't want to - nor do most have the necessary radio background.
As far as your MP3 player and speakers.....you won't likely be able to drive bigger speakers directly with the MP3 player, but you can buy amplified speakers or another audio amplifier that can be fed the output of your MP3 player, and then used to drive speakers in your shop.
Good Luck!
Rob Wallace (Amateur Station WA0RW)
Ken Garlock, Collin County Texas
>Hi Stuart.
Rob is on the right track for trouble shooting your problem. The source of your noise is most likely the electronic ballasts that are used in the T8 and smaller fixtures. BTW, the 8 in T8 means that the fluorescent tube is 8/10 of an inch in diameter. A t12 is 1.2 inches, etc. Unless you have a well made ballast transformer, (spelled A-d-v-a-n-c-e) you can have problems. I too have 6 T8 fixtures in my shop and I do not experience any RFI problems, either AM or FM. When we built, the electrician said he only used Advance ballasts, period.
Good Luck and let us know how your solve your problem,
Ken
K8CHO, extra class, licensed for 53 years, worked all states 50 MHz.
bernie feinerman
>The electronic ballasts used in most fixtures today are the source of noise. If possible, take the fixtures back and pick up fixtures that have a magnetic ballast and you will have less RFI.
Bob Ingram
>Buy a 3 to 2 plug adaptor (cheep one from wally world) plug into radio... My $600 (+) portable sound syatem has this same problem in one of the classrooms I use. A professional singer told he that they use the cheapo trick in a lot of churches they sing in....
Walter Ahlgrim
>Is this a problem with AM only?
Is this a problem with battery powered radios?
I just bought a new ballast only after I got it home did I see the label �for Industrial use only� With this label no RFI filtering is required by the FCC.
You could try adding RFI filters to each lamp.
Walta
Chris Friesen
>If you switch to magnetic ballast you will also lose efficiency and low-temperature operation. A better option would be to use higher-quality electronic ballasts.
Shop Lights Now No Radio-thanks everyone
Stuart Johnson
>To answer a couple questions. Both AM and FM are impacted. The lights are not on the same circuit as the radio.
With only 6 of an overall 30 lights I can't see going to the additional expense of find higher grade lights just so I can listen to the radio. I have found a couple station that come through without static. One has some sort of music(?) I can't begin to understand but the other one is okay for just adding a bit of background. I'll look around and find a radio / amplifier that will accept input from my MP3.
Once again thanks for all the very detailed help.
Re: Shop Lights Now No Radio-thanks everyone
Bob Macgregor
>One low-tech approach that sometimes works is to move the radio. There are ways to shield it, too, but relocating it in the shop sometimes puts it in an RF node (or dead zone) that allows it to receive broadcast with less interference. If it is line noise, you need either a filter or a higher-quality radio.
Its worth a try, anyway.
BOB
Bruce in Saint John, N.B. Canada
>Nice to see some Hams expressing their thoughts here. I was all set to give my 2 cents worth but no sence in repeating what others have already said. When it comes to static noise from a florescent light fixture,I personally have had better luck with the older magnetic ballasts than the newer electronic ones. It will be interesting to see how you make out correcting the problem. I often wonder how many woodturners are Ham Operators. GOOD LUCK Bruce (VE1ANH 38 years)
