Chainsaw Sharpener update
Ed Moore of SW VA
>After asking for suggestions I purchased a Northern Chainsaw Sharpener. Setting it up was quite easy - or should be if the right bolt was supplied. I had to go to Lowe's and get a 10mm bolt with coarse threads to connect the two main parts of the unit. The bolt supplied was far too small in diameter for the knob on the other side. Once I had it assembled I set the chainholder at 30 degrees and the vertical was put at 60 degrees. As I look at the paper supplied with the Stihl chain I see that some chains should be at 60 degrees and others at 75 degrees for the vertical. This should be interesting since I have two different style chains (one marked green and the other yellow). I think I better find out exactly which chains I have. In any case, I have sharpened four chains and found it to be quite easy. I like the clamping and indexing for the Northern better than for the Harbor Freight. With the Northern, the indexer is against the tooth being sharpened. The clamp is a cam that gives a good positive grip on the tooth. Gary Evans mentioned the importance of that good clamp and I am glad that I listened.
As I mentioned earlier, I paid $89.99 plus tax for the Northern Sharpener. I feel that I have gotten my money's worth and that this will be a quite serviceable piece of equipment. And after 15 or so chains have been sharpened I will have my money back. [grin]
Thanks,
Ed
