Delta 46-460 vs Jet 1220 VS
Bill Blasic
These are my findings concerning these two lathes:
Both of these lathes are variable speed with the Delta having a 1 HP motor compared to the Jets 3/4 HP motor. The main difference here being that the Delta speed ramping is much smoother than the Jet. The Jet doesn't seem to respond to the first half of the knob being turned to speed up, like you get all the speed ramping in the last half of the movement where the Delta has defined ramping as you turn the knob from one to nine.
The Delta is about two inches taller sitting on the same bench and this allows the motor to be positioned about two inches lower than the Jet, this does allow for easier cleaning of chips off the motor. There is a definite power increase with the 1 HP vs the 3/4 HP, it is noticeable. In my turning with the Delta the motor does get a lot warmer than the Jet, I've literally turned for hours with the Jet and the motor stays cool to the touch. Same with the bearing housing, the Jet runs cooler. This does not mean that there is a problem with the Delta just that after running for a few hours there is a difference between the two as far as heat goes.
The spacing of the bearings in the headstock is a little different as the Delta's bearing spread is 3/8 wider than the Jet. The bed dimentions are similar as far as thickness, spacing, etc. The fit and finish of both are very good and they seem to weigh about the same (Heavy for what is called a mini/midi lathe), around a 100 lbs. The locking mechanisms for belt changing are completely different and here the nod must go to the Delta as it is very easy to change the belt position with this system, just a push/pull arm located inside the belt area that locks and unlocks the system. The Jet has 6 pulley positions and the Delta has 3, the Delta's 3 positions are very wide and the belt is about twice as wide as the Jet's belt.
The locking handles on the Delta are a little longer and a little thicker than those of the Jet but both do their job. Both have 24 detents for indexing but each goes about it in a different manner. The Delta has reversing where the Jet does not. The Delta also has manual reset circuit breaker. The Delta can also be locked with a padlock to prevent its use. One big surprise about the Delta is that there is no parts diagram included in the manual nor was one in the box. Both have a 5 year limited warranty.
Bottom line is that there are now two great choices for someone looking for a mini/midi lathe. Both being able to easily attain bigger projects with less strain. The proof will be in the use over time. If I was pushed in a corner as to which I like best I guess the Delta would have a slight edge out of the box but as I said time will tell. I'm keeping both!!!
