When your calipers say 1/32", you should listen
Steven Antonucci
Steve antonucci
>Like Groundhog Day (the movie), I managed to lose another vessel (curly African Sumac from half of a piece sent to me by Jason Clark in the recent wood trade). I had carefully measured the wall thickness to 1/32" and knew not to cut there, but did anyway. In an instant, I had made the inside bigger than the outside.
For folks who routinely turn vessels 1/16" thick or less, how the heck do you get them off the lathe in one piece? All of the laser pointers I've seen have beams that are thicker than my wall diameters. Even calipers have enough error in them that make them imprecise for this application.
Is less than a real 1/16" in a hollowform just plain impossible?
Steve
P.S. Laser pointing would have at least told me I was in the "danger zone inside the vessel, even if it couldn't have measured 1/16" precisely...
Re: When your calipers say 1/32", you should listen
>Not impossible, I just don't do it often anymore because people feel they are too delicate and won't buy them. I don't usually shoot for less than 1/16, usually a little thinner than 1/8 is fine. I can hollow to 1/8 fairly quickly but to go thinner doubles or triples the time it takes to make something so I just don't do it unless I'm going to pierce the piece. I also blow them up more frequently and I don't have the time to waste pieces.
When using the lazar I use the edge of the lazar dot as my point of reference. I know I don't need to be that accurate but the anal in me makes me. I made my own plastic calipers and they are accurate to less than 1mm as long as I don't flex them. They are plastic.
Paul Zerjay
>I'd like to see a pic of those calipers John
>paul I'LL try to get one tonight. They aren't anything special. Just plexiglass "s's" laying over each other with a cheap plastic ruler glued to them. I'm going to make another pair shortly with a different curve because I'm doing some different shapes now and have trouble reaching all the areas.
Mike Stafford
Correction, you made the inside equal the outside.
Mike Stafford
Re: Correction, you made the inside equal the outs
David Walser
>I prefer: "I maximized the vessel's volume."
Steven Antonucci
Sort, I turned a good 1/16" on the outside too
Steve antonucci
>Although I suppose when there is no more wood to cut, cutting air through the new side vents (AKA chip removal slots) is pretty much something that has little value.
Steve
I like that David.
homemade calipers
>I made these about 8 years ago. They are still accurate but a little harder to read. I made them out of red plastic and then after a few years of using them like that I glued a piece of a plastic ruler to the end of one jaw. This made it very easy to get within 1mm on an exact thickness. I need to change the angle and make the loops more circular to reach into hollow vessels. This one only works if I have a reasonably large hole. It's perfect for bowls that aren't too large and vases up to 8" deep. You can make these in any shape. I cut out both sides at once, taped together so they match perfectly. The only hard part is drilling the hole accurately. Leave the legs just a hair long so you can fine tune the fit after you get them bolted together.
Re: homemade calipers
Paul Zerjay
>Thanks John
Juergen
>Steve, try this. Cover the laser with a patch of black electrical tape, find the thinnest needle in your wife's sewing kit and puncture a fine hole in the electrical tape. You may have to try this several times before you get the diameter you want. I've found if you heat the pin it makes a cleaner hole, but too hot will make the hole too large.
Rob Wallace
Rob Wallace
>Aluminum foil works very well for this 'aperture-making' application - I've done this many times for science demonstrations.
Rob Wallace
Steven Antonucci
Great idea- like a pinhole camera!
Steve antonucci
>I have been telling a couple of my buddies that i can build a hollowing system for under %25, and I think that's what i am going to do this afternoon!
Thanks for a great improvement idea that will make round one of the design!
Steve
