Lignum Vitae turning blanks
Gary Evans Tallassee, TN
>Hi all,
I was researching something else in McMaster-Carr and discovered that you can actually order a 12"x12"x12" turning blank!
Only $1382. I may get 2!
Gary
>Hi all,
Gary
I think it was used for bearings in ships?
Steve antonucci
>Probably cheaper than bronze...
S
Re: Lignum Vitae turning blanks
>Not doubting you, but a 8 x 8 x 3" blank runs about $40. I could see a large blank running maybe $500 - over a $1000 seems too high.
Re: Lignum Vitae turning blanks *LINK*
ebd
>Try West Penn Hardwood. They have both genuine Lignum & the Argentine variety. Prices are very good. The usual disclaimers.
West Penn Hardwoods
Bearings in clocks as well
Aage Rendalen
>Steve, in the 1700s chronometers used bearings made out of lignum vitae because the wood is so oily its self-lubricating. I came across the info in the book Longitude about the Harrison cronometers that solved the problem of calculating longitude (as opposed to latitude).
Re: I think it was used for bearings in ships?
GalenV in Iowa
>We used Lignum Vitae for many years as underwater bearings and wear blocks for municipal water and waste water treatment equipment. There are probably a lot of those parts still in used today from the 70's. In order to buy in later years we had to buy a small log and the price was like gold. I forget what year it became almost impossible to buy and by then plastics had started to take over for the same uses. The "plastic" UHMWP is now used for the same applications. Lignum Vitea was pretty much self lubricating so no worry about contamination of your drinking water from patroleum base lubricated bearings.
You may find as bearings in some old water windmills as well.
Galen
Eduardo sarmiento-hall
>Hi I have turned a lot of it,tell you the stuff is murder,is the hardest wood in the world,in Ecuador is very popular,most turnings are made from the stuff(also call guayacan) be prepared to have a good time and queep your steady rest very very close to the piece otherwise a cach will result in a broken tool for sure also the dust is terrible extremely fine and very toxic good turning my2cents
Jim Sebring
>Keep your grinder running. This stuff will dull your gouge in about 39 nanoseconds.
One of my carpenter uncles was assigned to Admiral Nimitz's flagship during WW II. He was requested to build a wardroom table for the Admiral. The only wood available on board of sufficient quantity was Lignum Vitae. My dear uncle said it destroyed all his edged tools!
>The McMaster/Carr catalog #111 that I was looking at was a few years old, but $1382.01 was the price for a 12"x12"x12" block. Part Number 5062K71.
A 24" long piece was $2487.62.
In the notes they say "Easy to machine." 8^]
Gary
Boiler's feet
Philip Duffy
>The LV wood was used to put under the boilers on a ship so that, as the ship moved up and down, and rolled, the boilers would slide on the feet and the pipes would stay connected. When saturated steam is the product in the pipes you cannot see it and it will cut you in half if it leaks out of the pipes. LV is the very best wood for the feet - -the ship's feet. Phil
Back in the 70's...
>... I used to buy a lot of my wood for high-end projects from Wm. L. Marshall, Ltd. in New York. They had a warehouse in Brooklyn, on the docks, where they held all their solid lumber inventory. It was nothing to see a stack of Brazilian rosewood next to stacks of tulipwood and English oak and other prized species that are much rarer or non-existent today. They also stocked a lot of lignum, in cants, rounds and blocks, for a few bucks a pound. I recall taking home large garbage cans full of leftover pieces, off fall, etc., that were perfectly lovely and sound. I used them consistently in my architectural work. Those days are apparently gone. I heard a couple years ago that some investors were attempting to corner the lignum vitae market. Maybe these new prices reflect that situation. Lignum is one of the most wonderful turning woods on the planet. I'd hate to see it be out of the reach of appreciative turners.
And, believe it or not - railroad ties
charlie belden
>The first transcontintal railroad was built acrossed the Isthmus of Panama - all of a little over 50 miles long. Because Panama has only two seasons, dry season and rainy season (and dry season usally falls on a Tuesday) they needed railroad ties that could stand up to being wet much of the year and wouldn't be eaten by termites and fungi.
When the Panama Canal was built, almost all of that railroad track (and ties) was submerged under the largest man made lake - prior to the Aswan Dam Project.
About a hundred years after that railroad was built Panama experienced an unprecidented drought and parts of the old railroad line was exposed. Opportunistic folks salvaged what they could get to. Removing the outside 1/8th inch of the ties exposed fresh sound wood.
And if you're one to drool over woods no longer available in fine quality, the Panama Canal Company, which built and operated the Panama Canal, built most of their two, three and even four story housing out of - old growth mahogany. Imagine square posts 24 - 30" square - forty feet long - in straight grain, old growth mahogany. Everything, except stair treads, was mahogany - painted Government Gray of course (sigh).
As a kid we used to paddle our dugout canoes - made from a mahogany log, up the many rivers. 18-20" wide, 12 - 14" deep and 16 to 20 feet long - dugout by hand. Price? Between $1-$2 - a lineal foot!
Re: And, believe it or not - railroad ties
RonZ
>I bought some railroad ties here in Israel from South America and it was from Goncolo Alves. A pain to turn but the results are beautiful.
