narrow parting tool
narrow parting tool
narrow parting tool
joaz
>What is the best way to sharpen the narrow parting tool?. Also, does the tool enter the wood with the long angle up or down?
Thanks all
Joaz
Re: narrow parting tool
>I'm not sure which one you have. I have a homemade one and I use the long point down so there is little chance for it to try and roll over sideways. I sharpen with just a very light touch of the short bevel on the grinder. About every 4 or 5 sharpenings I touch the long point to kind of reshape it back to the original position. When grinding the long point I run the stone down the whole edge.
Don Evans
>Joaz:
You use it with the long bevel up and sharpen it with a diamond. I use an EZE-Lap, stroke it from the point sliding it up towards the handle. Many, including myself added another bevel on the bottom side with the grinder, one time thing:
This extra bevel moves the point up on the tool so it is not at the bottom and keeps the tool straight as one cuts in. I have a picture that I did with paint and soon as I can find it I'll send it to you, come to think of it I can do it with digital of the actual tool.
Will send it sometime today. I use the eze lap on both bevels starting at the point. Other than that one time it has never seen a grinder, just a maybe 3 laps on each bevel before a cutting and it will last forever.
Don
Don Evans
>Forgot to mention I was in Maine just last Oct but now visit time.
You still shipping burls?
Don
Brad Vietje
Re: narrow parting tool *LINK*
Brad Vietje
>Joaz,
I think John asked the key question -- which one?
I have a thin fluted parting tool with the flute on the upper surface, which is longer), and that is sharpened with a DMT diamond "hone" on the short, flat side.
Other fluted parting tools are arranged differently -- in every case I can think of, you hone or sharpen the flat face, so where it intersects with the flute, two sharp points are produced to cut cleanly.
For non-fluted models, usually the longer edge is used upward, with a shorter section below. I would sharpen the shorter side with a diamond hone, and only touch it lightly to the grinder when needed. Another design is tapered for clearance, with the widest part downward in action. The one I've used had the shorter flat face facing down in use, and that's the side to sharpen.
I'll attempt to post a link to Sorby's parting tools, none of which are like the ones I have! Under the fluted part, they show a tapered model, and a thinner, fluted model on the right that's exactly the reverse of mine. Mine has a long fluted section on top, and a shorter, flat face below, like the photo attached here.
Safe spinning,
Brad Vietje
Newbury, VT
Robert Sorby Parting Tools
joaz
>Thanks all for the info. I need to buy a new one as I have a student coming for box making and when looking in my arsenal of tools I realized I had ground mine down to a very short narrow tool.
I'm concidering the Henry Taylor Tool. Craft Supplies has it for $25
which seems resonable to me for a tool that wont get that much use( I dont turn many box's but it looks like a good tool for first time students. Any thoughts?
Don...no I don't deal in burls anymore as most folks want small one's I only had large ones that I did not want to cut up. So I kept them for myself. But, I do have a good source for cherry burls now so let me know if you need any and I can let you know when I have some extra's.
Thanks...Joaz
www.maine-web.com/woodturning
Jorge Castaneda~Downeast Maine
>Compadre,
yo uso the parting tool as a miniature skew to shape things, to part I use a dozuki saw after marking the spot with the parting tool.
Jorge
Don Evans
>Here is the pix I promised although Brad has bet me to it, I promised so here goes.
This is the tool that comes with only one bevel with point at bottom. Moving the point makes the tool more self aligning and also easier to control in a deep cut.
Don Evans
>FYI -- each mark on the ruler used is 1/8".
Note that the point has been moved up but still below the mid point.
I lap both bevels instead of just one, this keeps the point in the same position relative to top and bottom of the tool.
Don
joaz
>Thanks Don and all, I have ordered the Sorby tool with the blunted tip. I hope it does the job.
Joaz
