Ok, I'm not turning anything, but I'm pondering using a turning inlay technique, and need some guidance: I'm refinishing a guitar that, ultimately, I'm hopeful will become my son's. The headstock's plain, and unadorned. He's suggesting either Mr. Game and Watch or a Zelda triforce as an inlay. Leaning heavily toward the triforce. Now, I'm not even going to try cutting and fitting mother of pearl for this; I'm thinking of excavating a cavity and inlaying some Inlace, or powdered metal, to create the design.
Anyone have an experience with any of the powdered inlay materials? Advice on this would be helpful - I'm guessing you'd slurry the powder with epoxy and fill the cavity with the mixture. I've used Lab Metal similarly, but not with spectacular results.
>Scott I've only used the metal powders a little. I've used Inlace a lot. I like Inlace a great deal except that I get air bubbles that have to be patched or filled in. That's a pain if you want a flawless finish. I haven't found a good solution yet. I patch the holes with medium CA or sometimes with a clear epoxy. I scrape these unlevel places down and then usually see some more. Still it makes a good looking final piece.
I've used the clear Inlace with metal powders or filings and I've also use Cast-n-craft which is a clear casting resin. I put the metal in there. The Cast-n-craft leaves less air bubbles but is very viscous so you have to make a sort of dam to contain it or keep the piece very level. I find you have to sand and polish the metal powders if you want them to look metalic, otherwise they look dull. I normally stop sanding at 400 to 600 but with the metal powders I find that I use 4/0 steel wool followed by a white rubbing compound to bring them up to a higher gloss.
Heat, carefully the inlay with a hair dryer. The heat will make the bubble come to the top where they can be picked if they don't burst on their own. Obviously you should use only very slow setting epoxy when doing inlay work. It's not a 5 min epoxy job.
I've worked with metal many times and have good luck with it using epoxy.
Mix the metal in with the resin first, they add hardner and mix, then pour into cavity. If at all possible, back cut the cavity at the bottom edge so the inlay can have a better grip. You can do this with a pick to cut away wood if that is only way to get in there. This way the inlay material runs into the cut and helps hold it in. I use the special pick made for cleaning out the fret slots on guitar necks.
I would use Pearl Ex pigments by Jacquard for the example you showed. You can get them at Dick Blick art supply via internet if no store close to you. These are powdered mica (man made) and come in many different colors. Make sure no wind is blowing when opening and don't breath in the powder.
>I have used powdered metal inlay on several pieces. I use mostly 600 mesh powdered brass, but have also used filings from making keys (obtained for free from the hardware store by volunteering to clean the key-cutting machine area) which gives an interesting "coarse metal" effect.
I have successfully used clear 20-minute epoxy as the binder for the metal powder, prepared pretty-much as described previously. I would suggest using a shellac sealer FIRST before cutting the inlay areas to keep metal inlay out of wood pores in those areas that you don't want metal. I found that trying to remove cured brass/epoxy mix from within wood pores to be a major PITA that was later avoided by sealing the area first with shellac, and then sanding away "excess" epoxy/brass from the wood surface. Same goes for using clear inlace with metal powder. Undercutting slightly and sealing the wood helps with the 'crispness' of the inlay lines.
Alternatively, I have successfully done inlay which looks like solid metal by placing dry brass powder (small area at a time) into the cut-out areas, tapping the piece to assure compaction of the metal powder in the grooves, and then binding the metal powder together with super-thin cyanoacrylate glue. Capillary action carries the glue into and throughout the metal powder and binds it to the wood as one large mass. Although this method is somewhat time consuming, the effect is worth it. I will try to attach an image of a piece I did in 2007 using the dry-metal-powder/CA glue method that was donated to the Central Iowa Symphony Fund Raising Auction. "Get in Treble" was billed as a turned wooden platter that "had its own Brass Band".
FWIW - The center three triangles in your design reminds me of the standard "Delta machinery" graphic logo that appears on knobs, etc. on many Delta machines. I have the same three triangles on my table saw and jointer.
I'm curious - where is Douglassville, PA?? (I've been all over the Keystone State, but don't know where you are located.....)
FWIW, I put in an order for some powdered brass and water-thin CA yesterday. Heading to Woodcraft today for a slew of finishing supplies, too. Fun begins tonight...
Douglassville is between Reading and Pottstown. About 45 minutes NW of Philly.
