Sanding & grain direction
Thad
>The thread below reminded me of a curiosity I had last night:
One technique mentioned below is sanding by hand. I assume this refers to having the turning in one hand, and sandpaper in another, and no power tool. When hand sanding, do you sand with the grain (as much as possible) or does it matter since turnings typically get sanded so finely?
I thought about turning a flat spindle (just straight, no beads or coves), taping it in the middle, then sanding the two halves differently. Half "A" I would sand as I would any spindle, while half "B" I would stop the lathe, and progress through the grits sanding with the grain. What do you think the differences in the finish would be on each half?
~ Thad in middle GA
