Sanding the outside of bowls
Aage Rendalen
>Power-sanding convex surfaces, such as the outside of a bowl, off the lathe, is a problem for me. I keep thinking there must be a more efficient way of doing it. Any suggestions?
Aage Rendalen
Re: Sanding the outside of bowls
Michael Bush------WebKitFormBoundarydY1jgPa9aVjvl+
>I'm showing my ignorance here, but I've never done it off the lathe. Why would one want do that?
Bob Macgregor
>If I have to do this I usually mount my velcro-backed sanding disk on the lathe (or mount it in a drill and clamp the drill in a bench vise... whatever works!) and sand hand-holding the bowl the same way you might buff with a Beall. Keep the bowl moving smoothly and don't press real hard...especially with coarser grits.
BOB
Carole Valentine
>I try to avoid sanding bowls off the lathe and I never power sand off the lathe. If I can't put it back, I hand sand.
Greg Haugen
>Michael, sanding a bowl off of the lathe would be an option if it was a "green bowl-turned finish" or for example a natural edge bowl with a really unique rim.
Ideally, a vacuum system could be used in the instance of a "turned green" bowl to remount the bowl without marring the surface. The lathe would have to be real slow so you're sanding all of the surface and not just the "high" spots from where the bowl distorted.
Or another option, as already mentioned, would be to mount the sanding discs on the lathe with a jacobs chuck and sand it in a similar manner to Beall buffing. Care has to be taken with this technique so "flats" are created and you keep your gentle curves. A ultra soft pad would be a good option compare to a firm pad so it contours to the bowl more and does sand "facets" especially with coarser grits. Bill Grumbine shows this technique in his second DVD when he sands a Natural Edge bowl. I highly recommend both of his DVDs!! www.wonderfulwood.com
Roger Dunn
>Aage,
When I need to, I use soft back sanding pads and velcro affixed disks with random orbit sanders in both 5" and 3" sizes. Orbital marks come out with finer grits and buffing to final finish.
Roger Dunn
www.morethansawdust.com
robo hippy
>I thin turn to final thickness and then let them dry and warp. I do all my sanding on the lathe. Power sanding is much more efficient than hand sanding, and even then, if you have the lathe hold it while you sand, it is like an extra set of helping hands. If you are power sanding a warped bowl, you need lathe speeds down to 10 rpm. You just can't keep your hands/sander/handheld abrasives on the wood at higher speeds. 3 phase vfd lathes can do this. The only reason to sand off the lathe that I can think of is would be to sand the bottom after you have turned off the recess or tenon. Do everything on the lathe that you can, then take it off for the last little bit. Much less work. Efficiency is intelligent laziness.
robo hippy
Greg Haugen
>Reed,
Don't you use a recess, instead of the conventional tenon, so you can sand your bowls back on the lathe, by expending into the recess to mount a finish turned bowl? If someone doesn't use the recess technique they still could put it back on the lathe with a vacuum.
Have you gotten your hands on the new Mark 8 Mcnaughton tool support yet?
Ditto what Carole says
keith zimmerman, Normal IL
Dick Coers
>I use my Porter-Cable "speedblock" sander when I want to sand off the lathe for the outside, and the 3" pad on the drill press on the inside.
Brad Vietje
>Aage,
I'm with Carole. Are you unable to re-mount the bowl between centers to sand it? I do almost all the sanding on the lathe. I commonly finish each bowl -- just as I start them -- between centers. I leave a little mark from the tail center from the original rough turning in place until the very end, even if I re-mount after air drying to finish turn months (or years) later. The small nib may be 5/8" or so when fresh, and I keep this size nub on the tenon until after almost all the sanding is done -- all except the details on the bottom of the foot. My method is below.
I have a few turned wooden disks that fit my chuck jaws and some that fit a "woodworm screw" that goes into the chuck. These disks are selected to fit inside the bowl, and covered with a soft rubber mat or a cloth, and then I bring up the tailstock to sand and finish the bowl on the lathe. When I finally finish turn the foot, sand and finish that, I end up with a tiny nub held by the tailstock, usually around 1/4 - 1/8" in diameter, that I remove by hand. That's the part I hand sand off the lathe.
If it's now oval, and I'm not re-turning it round, I do what Robo Hippy does -- I go real slow with the variable speed on low range, and power sand, or use hand-held abrasives while the lathe does most of the work. now, I find the outside pretty easy to sand, and most of my sanding woes are on the inside, especially around undercut rims.
Since I hate sanding, and sanding is probably the most dangerous part of turning, I do whatever I can to do less of it. I'm also very picky about finish quality, so if it has scratches or other finish problems, I won't sign it.
Safe spinning,
Brad Vietje
Newbury, VT
steve worcester
>If you must sand off the lathe, with power sanding, go with a thicker, soft interface pad. That way you won't have alot of issues with the undulations of the warping and what-not.
