Grinders
Grinders
Grinders
John Scheideman
>I'm wanting to buy a new grinder. I plan to put my Wolverine attachment on it. I was going to buy a Delta but I'm seeing some pretty bad reviews on the Delta 6" and 8" variable speed grinders. I'd welcome comments as to what everyone recommends. Thanks.
John
Re: Grinders
Re: Grinders
>I've got an 8" grinder that I got from Woodcraft (they now seem to have the 2-speed on a close-out special). It works quite well.
It's a good grinder - though if it doesn't work well out of the box, take it back and have them replace it.
The grinding wheels aren't the greatest. I replaced mine very quickly and donated the old ones.
Re: Grinders
Re: Grinders
>Ditto what JL said. I like my Woodcraft slow speed grinder. I wanted a BAldor but they are about 3 times as expensive and this machine has worked so well I'll just keep it. Mine came with one gray and one white wheel. I replaced the gray wheel and then used them both up before putting better quality white wheels on.
My new student bought one of the Delta grinders. It seems to be OK but the wheels are rediculously soft. He's ground away 1/2" and he's only been turning 2 months. It grooves badly with even very light grinding.
Re: Grinders
Re: Grinders
Bruce in Saint John, N.B. Canada
>I own and use a Delta V/S grinder (GR-450), and heaven forbid I haven't experienced any trouble with it and certainly hope I don't. I replaced both stones with Norton 3X Blue stones. I'm really pleased with the job that it does and would purchase one again in a heart beat. Good luck on your decision.
Re: Grinders
Re: Grinders
JohnKyler
>I have the Delta 8inch and use it with the Wolverine, and it is great!
Re: Grinders
Ditto
Barbara Gill, Remlik VA
>I wouldn't buy anything Delta after some of my past experiences with poor quality.
Re: Grinders
Re: Grinders
Bruce McElhaney, Spring Lake, Michigan
>I have a 6" Baldor slow speed grinder and a 8" Delta slow speed grinder. The Baldor is much smoother, no question about it. The Delta is heavy duty and powerful, but quirky (had to replace the on/off switch) and it vibrates too much even though It's mounted on a heavy duty, steel, floor stand. Tried new Norton wheels on it, but that didn't help much. I even tried to fit Oneway's wheel balancing system on the Delta but couldn't get it to fit right and had to return it. So for now, I'm sticking the blue Baldor. I'd love to have an 8" slow speed Baldor, but it's very pricy. A Baldor 6" grinder is a lot cheaper than the 8" version.
Re: Grinders
Brian McKearney
Re: Grinders
Brian McKearney
>I've got the Delta 8" variable speed grinder (had it for a couple of years now) and have had no trouble whatsoever. I would highly recommend it to others based on my experience.
Re: Grinders
Re: Grinders
Don Evans
>I've seen several comments here that make me wonder if all are taking everthing into consideration. Easy not to do, but blanket comments aren't helpful in these cases.
Just saying that someone wears out wheels quickly and that's it doesn't do much.... What wheels were they using? The wheels can be purchased in many many different hard or softness levels and depending on what they have is the main event...
I have had for sometime now a 6" Baldor grinder made in the 60's and it is top notch no question and I keep a grey wheel and wire brush on it for heavy metal working. This was a $1000 grinder back then and it just cannot be compared to what is out there today trying to compete with people looking for the best cost wise bargain!
I also have a Delta 8" 1750 rpm (not variable speed) that I have the Wolverine on it and use it for light work. Like sharpening turning tools and a grey wheel on left side for light duty shaping.
Wheels -- for woodturning sharpening you want a wheel that is mid range in hardness of J or K, grit isn't really that important for turning so anything form 80 to 120 is ok, I use 120 white. A wheel like described last me long time. When I was turning daily I would get 6 to 8 months out of it. How well you maintain the wheel also is a factor. I saw a "youtube" on turning the other day where the white wheel the guy was using was pure black when he was sharpening, just wasting wheel and tool.
A new tool is shaped on the grey wheel and from that point on is used on white wheel with only two passes left and right take about 3 seconds. Every 2 or 3 sharpening the wheel is shaped and cleaned with diamond "T" handle.
I've even got this grinder set up on an old bag type (bags are gone) dust collector that exhaust outside. Keeps shop really clean.
I have the Baldor mounted on a 4 wheel cart that goes outside for heavy grinding.
If to do all over today, I would do the same thing, Delta 1750 rpm with white J/K wheels. I would not get the variable speed model and it isn't needed and therefore is something extra to break. With grinders remember the "KISS" theory.
Don
Re: Grinders
Re: Grinders
Don Evans
>I should have added that I also use OneWay wheel balancers on my white wheels, they work great and do have a slight learning curve to get it just right. All white wheels that I have experience with MUST be balanced. No experience with the blue one's as I believe if something is working for me, and it is, why try to fix it.
Don
Re: Grinders
Re: Grinders
keith zimmerman, Normal IL
>I have a 6" Delta that is NOT VS with my wolverine. This is what I had when I bought my Wolverine and that is where I established the grinds I use. I also use the Norton 3X 80 and 120 grit wheels.
It works quite well for me.
keithz
Re: Grinders
Thanks for all the help from everyone!
John Scheideman
