New use for double-stick tape
Keith Tompkins
>To sand the carved areas of my turnings, I usually glue a sheet of sandpaper to a piece of veneer with yellow glue, clamp it overnight, and then cut it into appropriate sized strips. The nice thing about this method is that the veneer prevents the sandpaper from cutting where I don't want it to cut...I can run the paper along a carved line without disturbing the line. Problem is, if I run out of strips, I have to go through the whole glue-up procedure. Well, I ran out, and couldn't wait for the glue to dry, so....I applied double-stick tape to pieces of veneer, and then added the abrasive paper. Voila! Back in business! AND, I can put a different grit on either side; works like a charm.
