Re: Five Inch Hook & Loop Holders------WebKitFormB
Greg Haugen
>Try Bruce Hoover at www.thesandingglove.com
I've also bought 3M and Norton 5" H&L holders along with discs (not the best quality discs) at Menard's or Home Depot for sanding the flat areas on my door stops.
Woodcraft also carries some brands of discs and holders in the 5" size. I'm thinking specifically of Abranet discs and holders.
Re: Five Inch Hook & Loop Holders------WebKitFormBound
Re: Five Inch Hook & Loop Holders------WebKitFormB *LINK*
Rob Wallace
>Emmett:
Klingspor's Woodworking Shop (URL Below) certainly has 5" H&L abrasive disks...as do many woodworking suppliers (...you'd probably want the "solid" kind - those without holes).
You may need to make your own 5" sanding disk holders from those "rubber" backed 5" disk holders, often used for auto-body repair (self-adhesive H&L retrofit/repair material is available). I've never seen 5" disk holders with typical 1/4" shanks offered through woodturning suppliers like those that are offered in 1", 2" and 3" sizes. I have a few 5" abrasive disk holders with 1/4" shanks that have seen their fair share of sheet metal and Bondo... you might consider layering some heavy duty foam between the disk holder surface and the hook material.
Greg Haugen
>Rob and Emmett,
The Sanding Glove does have 5" H&L that are identical to their 2" and 3" disc holders that comes in soft, medium, and firm densities. A small picture is on the front page of the site or on the 6th page of the catalog. They are $15.95 as of the winter catalog. They do also have "interface" pads of different densities in the 5" size. Klingspor's also have 5" pads that are identical to the 2" and 3" holders for the same price, page 18 of the No. 120 catalog/flyer.
Menard's 3M holders do have a soft sponge/rubber backing that is very nice-not as thick as the other pads above but better than the automotive pads. I like it a lot and they're in the $6 range with a 1/4" shank.
Ellsworth in his book and/or in one of his videos explains how to make a "softer" pad out of a hard automotive pads.
Not affiliated with any of the suppliers, just trying to provide information.
