THE WOODRAT IS BACK!
PVC
PVC
Dick Hines
PVC
Dick Hines
>I am looking for PVC that is in a form of a solid rod or block. A friend of mine makes bird houses out of PVC sheeting. The only thing that is not is the roof and the finial on top. He would like me to turn some PVC finials.
Has anyone got any ideas?
Re: PVC
Wow! That's some expensive stuff!
Al Neighbors
Re: PVC
Re: PVC
Carole Valentine
>Couldn't pay me enough to turn that stuff any more than I am forced to in order to make vac chucks.
Re: PVC
as Carole, ...
GaryG in MD
>I have found it quite difficult to turn PVC without a catch. I'm sure I could learn and improve with practice, but I think I'll forego that questionable pleasure. ...Gary
Re: PVC
Re: as Carole, ...
Don Evans
>Don't understand the problem as pvc turns very nice but you turn it just like wood, with spindle gouge etc, DON'T use scrapers.
Here is a place to check out, as noted there is some of these manmade things that are very expensive and there are those that are not. You may find something that will work without any work except cutting to length.
Don
Re: PVC
Re: as Carole, ...
Carole Valentine
>Don, it's not that it's hard to turn... I just don't like the smell of the stuff and I dislike even more it's static properties. The fine shavings seem to stick to everything like magnets.
Re: PVC
Re: as Carole, ...
GaryG in MD
>Don, Yeah, I was trying to true up the end of a PVC cylinder with a scraper when I had my problems. ...Gary
Re: PVC
Dick Hines
Re: as Carole, ...
Dick Hines
>Don you did not put the place in your post.
Re: PVC
Re: as Carole, ... *LINK*
Don Evans
>Dick:
I'm positive I put the link in the "link" box but it didn't show. I just noticed that John Lucus did same thing in a post that I read this morning, wonder if there is a problem Ellis?
Trying again, but just in case here it is:
www.usplastics.com
Don
U. S. Plastic
