On The Origins and Uses of Decorative Elements
charlie belden
>We all are carrying on a very ancient craft that probably originated not long after our ancestors learned to work with fire - because then we needed something to hold hot liquids - soups and stews.
I suspect some female, and it was probably a female, in our hunter/gatherer days, was scraping out the edible parts of a gourd or shell and had an AHA! Moment - "Hey! This could hold stuff - especially liquid stuff! AND - it's light and portable. I'm going to have to tell my female friends about this."
And thus the bowl and hollow form came to be.
Later, while "the guys" were scratching hunting plans in the dirt with a stick, she (let's call her Jennifer) was carefully scratching patterns that were pleasing to her in the outside of one of her hollowed out gourds - with a sharp little piece of a rock that had chiipped off one of the rocks around the fire. She found the results pleasing to her - so she showed her friends, and showed them how she'd done it. Some copied her patterns and some came up with their own patterns - and showed their friends.
Now things we hold precious, either for practical reasons or sentimental reasons, often get damaged and sometimes broken. Those we either fix or find some way of saving at least a part of that which we hold precious - an amulet, necklace, bracelet or perhaps and earring?
And thus Jewelry was born.
(Sorry for the digression)
At some point - the "guys" got involved.
"You know, dear, those hollowed out gourds are kind of delicate and it seems as though they're proned to cracking and splitting and chipping - especially around the rim. And my gourd soup bowl seems to tip over when I set it down on the cave floor, often spilling some of your EXCELLENT soup.
Jen, I was thinking, maybe if the rim could be made thicker it'd be less apt to break off in places like gourds seem to sometimes do. And I was thinking a flat on the bottom might keep it from tipping over so easily - and spilling your EXCELLENT soups and stews.
So, while you and the kids were away visiting your mother, I took a burnt chuck of wood from the fire pit, started scraping off the softer charred wood and by carefully placing hot coals in one area of it and scraping off that charred wood. Look - I made you THIS WOODEN BOWL - which won't tip over - and spill your WONDERFUL soups and stews.
HAPPY ANNIVERSARY! I bet you thought I'd forgotten. Oh, and here are some flowers I picked for you. Just something pretty for a very pretty lady."
And thus - wooden bowls and wooden hollow forms came to be. (And the first "sensitive male" arrived on the scene).
Over time, the design of bowls and hollow forms evolved. Special shapes for specific use were developed and modified - initially for practical reasons, some thicker at the bottom for better stability, some with a wider or narrower foot, some with rims that made lifting and holding them up easier (the dawn of ergonomics?), etc., etc., etc..
While guys went after Practical, gals pursued Pleasing and Pretty as well. With better fine motor skills and visual acuity, I'm betting it was the females of the species who came up with beads and coves. "V" grooves and Ogees that we use today improving the practicality of wooden bowls and wooden hollow forms AND the Pleasing and Pretty part as well.
Somewhere along the jourey through time, turning arrived on the scene and somebody found a way to do end grain hollowing, probably still using a hot coal or two to make hollowing eaiser since Carbide Tipped Insert Tools and Captured Hollowing Systems were many millenium away and turners had only Scrapers to use. Like any new technology, it was initially utilize to do things that were already being done some other, more time consuming way. For that reason, and I'm just guessing here, early turners basically duplicated the familiar - on the advice of The Marketing Department - "Stick with what they like - but jazz it up a bit. We want to catch their eye - and their trading beads". And the Engineering Department suggested putting three holes around the rim of bowls for making soups and stews so cords could be strung through them, thus allowing the cooking bowl to be hung OVER the fire rather than IN the fire or ON the fire.
The turner added some things that made his or her life easier - reinforcements that prevented the bowl from flexing or cracking during the turning process - ribs and beads, disguising them as "decorative elements" to keep The Marketing Department happy.
Let's jump way ahead in this story - to today.
If you think about it, not much has changed. Sure, we have better tools and equiptment, but we're still turning wood into something that will remove some of it - where we want wood removed - and we're still trying to keep the centerline of the piece fixed while we spin the wood into a cutting tool. And beads, coves, Ogees and other ALSO decorative elements can also serve a useful purpose - if you think about it - and utilize them well.
So I give you a semi-extreme case where beads served a very practical purpose - the Bot Sugar Bowl. The design criteria dictated the need for the piece to be as light as possible, a place for the micro robot BOT to be hidden under it and something that looks familiar enough to look suspicious.
Pulling this one off required a lot of chucking and reverse chucking, initially gripping from the outside and later from the inside (compression and expansion forces respectively).
Note the bead on the inside and outside rim of the bowl as well as on the outside rim of the lid. Note the TWO beads where the bowl and foot join. Now think of the jaws of the chuck holding the piece for turning. See where the outward pressure is applied? See where the reinforcing beads are? They're there for a reason - and not just for aesthetics. Perhaps a far better turner than I am could turn this piece without them - but I'm not that good. So those beads were my insurance policy - a little reinforcement where potential problems lurked.
The point of this overly long story?
If you think about the turning process FIRST, identify potential problems of the turning process required and use "decorative elements" to reduce the risk of those potential problems - you're more apt to succeed - and - end up with a completed piece - that's also Pleasing and maybe even Pretty.
And THAT will probably cause the original Jennifer to smile with just a hint of motherly pride.
Happy Mothers Day "Jen" - and all the other moms out there.
Re: On The Origins and Uses of Decorative Elements
Molly Winton
>Charlie, you seriously need a hobby....oh wait, you turn....Dude, get out to the shop! : )
charlie belden
>Molly:
The two BOT (micro robot) pieces satiated my turning addiction and I find that in order to avoid Post Project Depression a little reflection time is therapeutic - and sometime a way of gaining insight about something. In this case it was the structural importance of some "decorative" elements that actually have a practical reason for being where they are - in this case strength.
Putting pen to paper and writing about one of these musings often gives my Muse something to play with. If she comes up with something she'll let me know somehow, perhaps a year or two from now, or maybe tomorrow.
Sometimes time at the lathe may be the Muse's opportunity to pass on an idea. But I find that she seems to prefer quiet, more reflective times, to whisper an idea for the next Wild Hare project. Those Wild Hare Ideas often require some thinking and drawing and planning in order to work out a way to make them a reality.
I guess I could have used the time to clean up the shop and put stuff away - but - like many "moms" (I raised a son as a single parent, and some of a step son - who I still, and always will considered one of my kids - so I was "mom" AND "dad") - I dislike doing "house work" and most other "domestic chores/work".
Sometimes time at the lathe provides opportunities for an interesting piece. Other times a bit of time away works better - for me.
Currently The Muse is yelling "SOUND!" So I'm scheming on ways to add sound - or sound as well as movement - to a future piece.
I do find that sometimes thinking and acting silly gets my Muse in a communicative mood ; )
