End grain hollowing.... *LINK*
Marc Phillips
>Spindle gouge VS Bowl gouge.... ?
I have been using my bowl gouge (fingernail grind) in exactly the same manner that this video shows... with mixed results depending on depth, type of wood, steepness of the hollowing, etc, etc... Seems to work ok most of the time.
I watched this video, and am wondering if a 1/2" spindle gouge with a fingernail grind is in my future :)
Do you use the spindle gouge with a fingernail grind like this?... and any other uses in bowl and hollow form turning?
Thanks...
Video using spindle gouge for hollowing
Re: End grain hollowing.... *LINK*
Russ Fairfield
>It looks to me like he is using the spindle gouge to make a "scraping" cut. There is nothing wrong with doing that, or using a scraper for end-grain hollowing. I prefer to use a tool where I can slide along on the bevel and get a better quality cut whenever I can.
Marc Phillips
>That is what I thought interesting... hard to really tell from the video but he did state a couple of times that is was a quality cut... although it does look like a scraping cut....
Steven Antonucci
Spindle gouge and the Raffan Uppercut
Steve antonucci
>It's a great cut for doing things like he's doing, but not for everyone. If you google raffan upper cut or go to the woodworkingchannel.com and watch the Andre Martel video in the AAW section, you'll see what I mean.
It took me a while, but I think it's worth learning.
Otherwise. I'd cut with a hook. You can see Andre cut with a hook in the same video.
Steve
Re: This is very similar to the way.....
Jamie Donaldson
>....that Ray Key hollows boxes, and markets a custom ground tool with the R side ground way back for smoothing the exterior as well with the same spindle gouge.
Ron Lynch
>I've used this technique since I saw it on the Richard Raffan "Turning Wood" DVD. It does give a quality finish, however I've never used it for deep hollowing.
Keith Tompkins
Keith Tompkins
>Hi Marc, I use the same technique, except I use a round detail gouge, with the wings ground way back, about an inch. I also custom-made a deep hollowing version, a 5/8" steel rod with a 1/4" hole in the end with a set-screw for holding a cutter. It fits into a Kelton handle, and will hollow 12" or more.
Mike Stafford
Mike Stafford
>I also use a detail gouge with a steep bevel on the end and the wings swept back.
It is a scraping cut but nevertheless you are able to get nice curlies if the tool is sharp.
Steven Antonucci
Not picturing it...
Steve antonucci
>I don't understand what you meant by the rod and the gouge combo... Do you have a picture?
S
Keith Tompkins
Keith Tompkins
>Hey Mike, Yep...I turn at the highest possible speed as well, then finish up with the Hunter tool if needed.
>I use either a detail gouge or a bowl gouge more or less in the same way as the video. I start with the flute up or slightly CCW and then as the cut progresses the flute is rotated more CCW. I use the bowl gouge or detail gouge because they have thicker bodies and vibrate less as you hang them over the tool rest.
If the wood tends to tear out I will follow this with the Hunter tool across the bottom and use the detail gouge straight down the side from lip toward bottom. On larger end grain vessels I have a hunter tool that is mounted at an angle off the shaft so I can use it like you would a ring or hook tool to finish up the sides.
Keith Tompkins
Re: Not picturing it...
Keith Tompkins
>Hey Steve, I don't have a photo, but, imagine taking a detail gouge, and cutting off the cutting portion, and inserting it into a solid steel bar that's 5/8" in diameter. I drilled a hole in the end of the bar to accept the cutting end, and secured it with a set screw. Voila...I can change tips, too. My hook tool, and termite tool will fit as well. Hope this helps.
Steven Antonucci
So, long and strong?
Steve antonucci
>I have one from a broken bowl gouge that I use that way somewhere. The missing link was that it was a cutoff...
Thanks
s
Mike Stafford
Ditto on the speed and the Hunters!
Mike Stafford
Mike Stafford
Mike Stafford
>I love the 1/2" Henry Taylor detail gouge with a short end grind and swept back wings for Hollowing. It provides the long and strong for me as it has a lot of steel under the flute.
Much like John, I use the Hunters to clean up the end grain. High rpm but slow and steady movement across the bottom will leave a near polished finish.
