chucking something small
mike mcnerney
>I want to chuck a guitar bridge pin & cange the taper from 5 de. to 3 de. they are about 1 1/8 long the tapered section is about 3/4" long
& about 5/32 at he small end & 7/32 at the large. The only idea I have had so far is to drill a 5/32" hole in a hardwood or aluminum block mounted on a 3" face plate & then mount a block in the tailstock live center that has a approx 1/4" hole to a depth of 3/16" in & maybe glue something (fine sand) to give it some friction.
I will grind a 1/2" chisel to a 3 de. angle & scrape it down
Re: chucking something small
Re: chucking something small *LINK*
Greg Haugen
>If this is a one time project, if sounds like you have a good approach to it. Some other options would be "pin/spigot/#1" (every manufacturer calls them something different) jaws for a chuck or a collet chuck. I use a collet chuck, 3/8", on a draw bar (threaded rod with a block of wood and a nut on one end) to hold the dowels to turn bottle corkers. They work great. I'd think they would make the right size.
Just a few more ideas. Your idea sure does sound like it would work.
Little Machine Shop's Collets
underhand!
David Belser
>Sorry, I couldn't resist :)
Cut a slot to the center hole in a small block/plug and make what in effect is a single slot collet chuck or pin vise. I'd cut the slot first, turn the plug then use a tail stock chuck to drill the center.
When you tighten the jaws on the plug, the hole will close.
- Dave
Steven Antonucci
make a collet
Steve antonucci
>Take a chuck and turn a small end grain fixture to about 1/2"
drill a hole with the lathe
Thread the end with a die
without removing the fixture from the chuck, bandsaw an X into the threaded end
put a hardware nut that matches the threads you've cut
Should take you 5 minutes, and it's a single use collet, since I doubt it would ever run true a second time...
Steve
Re: underhand!
>put a piece of soft wood in your chuck. Drill a hole about the size of the ball end. Push the part into that hole. It should be a very snug fit. You could split then ends with a bandsaw and then clamp them together to make a collet like Steve suggested. I would bring up the tailstock to lightly support the loose end. Then just use a skew or spindle gouge to turn down the pin.
Re: underhand!
Michael Mocho------WebKitFormBoundarylK40+DdFANqFE
>Why do you need to turn down the pin? it is much more common in guitar repair to slightly ream out the hole with a standard tapered reamer. Inexpensive reamers made for bridge pins can be found at Stewart MacDonald or Grizzly for just a few dollars. (They also sell bridge pins).
If you do feel you have to turn down the pin, use high rpm and a flat single-cut mill file- you will have a better chance of maintaining the flat taper, especially if it already has a string slot in it. You may even be able to chuck it into an electric hand drill if you can grab the head in the Jacobs chuck.
Re: underhand!
mike mcnerney
>thanks all
John I like that idea though I think it will have to be hardwood, 6 pins. But I think I will have to center drill for the tailstock & it is already 5/32 & How do I center drill it accurately, maybe just eyeballing with an awl is OK. It is ebony.
I mistakenly bought a 3 de taper & pins at my store & stew mace are 5 de. Of course I will eventually get the 5 de. But in Canada it takes 3 weeks for delivery & I dneed this yesterday.
Mike
Re: underhand!
>Mike I make wooden adaptors for my tailstock. You could build one of those and put a slight dimple in the end to accept the end of the pin. This part would not get turned down of course but you could easily hand file the very end after youturn the rest.
Michael's method of using the file is a good idea. I would be a little leary of the drill chuck because it will leave 3 dents in the ball end.
