Re: The advice given...
David Walser
>Since a number of you asked, I'll pass on the advice Roger gave me. Note two things: First, the advice may only apply to my situation. Second, what Roger said may seem painfully obvious to many of you. I'm a CPA and don't repair lathes for a living. What he said was very helpful to me. So, if you must laugh, just don't do so whenever we might meet. ("Oh, you're the guy who didn't know... Ha!" Pointing and laughing is very rude behavior, but it's worse when it's done in bed.)
Anyway, with that necessary introduction out of the way, Roger said he thought my lathe might be having two related problems. First, he thought the VFD might be getting too hot. The VFD has a large heat sink that may have become coated with dust that was preventing the VFD from cooling properly. So, he told me where to find the VFD, how to gain access to it, and had me blow it off with compressed air. That took all of 10 minutes. He also suggested leaving the VFD out on the floor for the next 2 or 3 turning sessions so I could see any error codes the VFD might produce. (The manual for the VFD was stored in the tailstock-end leg of the lathe's stand.)
The second problem Roger wanted me to check on was the power switch for the lathe. (In addition to the power switch, the lathe has a start/stop switch to turn the lathe's motor on and off and a variable speed dial to slow down/speed up the lathe.) About a year after I bought the lathe, the power switch quit working reliably. It would take some twisting and vibrating of the knob to get the green power light to come on. So, in frustration, I just left it "on" and turned the power off at the circuit breaker. A year or so later, the green light went out, but the lathe kept running as before. Roger wanted me to clean the power switch by disassembling it. He hoped cleaning it would restore the switch to working order. It didn't. I took it to the local WW Grainger store and they said the switch needed to be replaced. The new switch and the new green indicator light were not the same size as the parts they replaced. (The old light was 3/8" in diameter and the new one as 1/2", for example.) After some effort, which included splicing in the new light (the new switch's terminals were not large enough to accommodate both the 10g power wires and the wires from the indicator light) and other things, I was able to get the lathe buttoned up. She ran as smoothly as ever.
It was too late to start a turning project, but I was sorely tempted to sit in my shop and watch the lathe's one green eye glow in the dark. Instead, I soaked in the hot tub and went to bed.
