Drill bit...
Drill bit...
Drill bit...
Marc Phillips
>Can someone point me in the right direction to get one of those long drill bits with the wooden handle so I can drill the center of hollow forms?
Thanks...
Re: Drill bit...
Craft Supplies USA ?
Don Orr
Re: Drill bit...
Mike Peace
Re: Craft Supplies USA ?
Mike Peace
>Lowes or Home depot if you don't mind paying less and putting on your own handle.
Re: Drill bit...
Re: Drill bit...
Pete in Holland, MI
>Just built one last week.
$15 for a 1/2" bit at Home Depot. $.90 for a 1" copper pipe coupling. A squirt of epoxy and a piece of hardwood.
Make sure to grind some flats/teeth into the shank of the drill for the epoxy to bond to. Drill a 3/8" hole about 2-1/2" deep, then counter bore 1/2" diameter to about 1-1/2" deep (that is, if you have a reduced shank drill). Drill a 1/16" vent hole thru the side of the handle to the bottom of the hole, else you'll get a hydraulic-lock as you try to force the drill into the hole.
Opted not to buy a 1/2" drill whose majority of the shank body had been reduced to 3/8". Mine is 1/2" all the way till the last 1-1/2" that is reduced to a 3/8" hex.
Turn the handle without any flats on it(if it grabs, it won't tear up your hand), but turn the handle with a rise or collar of sorts for your hand to push up against.
Took me about an hour one night.
Pete
Re: Drill bit...
Any hardware store
Jorge Castaneda~Downeast Maine
>Marc,
Any hardware store carries electrician drill bits, sometimes they call them "bell hangers" they have no handle, you can make one or just use a vise grip to hold it. That will be a lot cheaper than the very long drill bits sold by Packard of Craft supplies, if you need one that long, you can make it yourself, do search for "D bits"
We have discussed that before
Jorge
Re: Drill bit...
Re: Any hardware store
Jim Sebring
>Harbor Freight sells a set of three long twist drill bits for cheap. I made a handle from a scrap of Maple and a copper pipe piece ferrule for the 3/8 bit. I also filed notches every inch on one of the bit flutes to use as a depth gauge. Prolly have all of $3 in the rig.
Re: Drill bit...
Re: Drill bit...
Don Evans
>Marc:
Is this for using "through" the tailstock? If so, most of them I've seen a 3/8", used for boring when something is between centers. You can still use the above advise but the "bell hangers" bit is probably only one that will be long enough in this example.
If you are looking for want is commonly called a "D" bit by this site they are really "split bits" from metal working. If searching industrial supplies try both terms.
Industrial supplies:
www.mscdirect.com
www.use-enco.com
Don
Re: Drill bit...
Re: Drill bit...
Marc Phillips
>I was looking for a bit to hold by hand for drilling out and measuring depth of hollow forms... I watched a video I just ordered on hollow forms and he used a hand held drill bit with a wooden handle...
I just ordered a set from Harbor Freight and will make handles for them when they arrive and go from there..
