reversing motor
BQ in VT
>never having owned a lathe with a reversing motor, when would you run the motor in reverse? When running in reverse, do you then run the risk of a chuck loosening up? As always, thank you in advance for your time.
reversing motor
BQ in VT
Re: reversing motor
Cyril Griesbach
>BQ,
The most often use of reverse would be sanding...reversing the direction of the lathe with each change of sanding grit. Done at slow speeds and mild pressure on the piece I've not had a chuck come loose.
While I've not done it I've heard of folks turning in reverse and standing on the back side of the lathe in attempts to deal with tearout of difficult woods. Most chucks have a threaded hole in the insert for a grub screw to prevent the chuck from coming loose in this situation.
There are likely to be other reasons so we may both learn more with additional responses.
Re: reversing motor
Rick Allen
>I use reverse when dismounting buffing wheels. Actually I switch the direction on the fly and as the buffing wheel comes to a stop I grab hold and let the lathe spinning up into reverse un-thread the buffing wheel. I will also mount the buffing wheel by switching the lathe from reverse to forward.
Sanding direction change for each of the finer grits is often a good choice.
When mounting on the outboard I will use reverse to keep the force of the threading holding the chuck or faceplate.
Re: reversing motor
Pete in Holland, MI
>I sand a lot in reverse. Paper & hands are on top, and dust expells to the rear towards my collector. No problems having chuck unscrew to date, but don't apply heavy pressure sanding, nor shock it to cause it to unscrew.
Re: reversing motor
Dave Anderson (PacNW)
>I often turn in reverse, especially when my back is bothering me. By turning in reverse I don't have to bend over the bed to see what I am doing. Just make sure to use set screws in your chuck or face plate to prevent it from unscrewing.
Re: reversing motor
Brad Vietje
>BQ,
Used most often for sanding, or for turning outboard.
I never reverse the lathe while its spinning, but it never seems to hurt other people's lathes (when they do it).
Chucks and faceplates can potentially come off if not locked down with a grub screw if you have a bad catch or other violent episode (best avoided). If you have good mating contact between the chuck and spindle, they probably won't come off, but a heavy, wet chunk of wood could, if jarred. Oneway stuff has grub screw, some others don't.
Safe spinning,
Brad Vietje
Newbury, VT
Re: reversing motor
Bob Macgregor
>My chucks don't have set screws, so I have been leery of using the reverse function much. I have thought of trying to drill a hole in the insert to add a set screw, but I presume there would need to be a set screw against the spindle and another against the chuck, so the insert couldn't unscrew from the spindle and the chuck couldn't unscrew from the insert. Or, maybe it would work to put some locktite on the chuck side of the insert and a set screw on the spindle side?
Finally, for chucks with set screws, do the screws seat onto the unthreaded part of the spindle?
BOB
Re: reversing motor
Bill Howatt
>It depends on the chuck and spindle. Oneway chucks are made so the set-screw contacts and unthreaded portion of the spindle. A Oneway chuck on my General 260 causes the set-screw to contact the spindle threads. You can buy plastic tipped set-screws or you can put a small piece of brass into the hole and then put in the set-screw.
I think a fairly light tightening of the set-screw is all that is required to keep the chuck from turning. Note that on Oneway chucks, and perhaps others, you can put it 2 screws so that is even better for light tightening.
Bill
