Bubinga and Blackwood
Toney Robertson
>9 1/4" x 9 1/2" - Teak Oil - Not buffed yet. Second finial and lidded bowl.
Re: Bubinga and Blackwood
Pic #2
Toney Robertson
Re: Pic #3
Toney Robertson
Ricc Havens
>WOW! I am a lurker here since I had to sell my equipment due to job loss a couple years ago. I don't post hardly at all since I can't turn.
But, I just had to say - this LOOKS AMAZING. I like the color combination and design.
Sure makes me wish I could afford a lathe again!
Thanks for posting your pics
Ricc Havens
beautiful Tony
keith zimmerman, Normal IL
>This is a really nice piece and I like it a lot. The only thing I would like to see on it is for the upper shaft of the finial to be a bit thinner. It would add to the feeling of lightness that the remainder of the form shows.
keithz
charlie belden
>As othersw have noted - a very nice piece from some very nice wood. Also as noted, the finial slimmed down would be in keeping with the two upward sweeps of the lid. Took the liberty of tweeking one or your pics to thin down the finial - perhaps a tad too much - but illustrates the idea.
BTW - the photography is really nice work as well.
Toney Robertson
>Interesting. I like your version.
Thanks, I will keep that in mind next time.
Toney
Re:Toney-there are a number of hexagon.....
Jamie Donaldson
>...shaped artifacts in the dark areas of your images, indicating that you may need to clean your lens. That's a nice looking turning BTW.
Keith Tompkins
Re: Pic #2
Keith Tompkins
>HI Toney, Great looking piece. I have a question concerning how the finial was attached...the lid appears to be cross grain, while the finial is spindle-grain oriented. Did you create a round tenon to secure the finial? My concern is over time wood movement will create a step or gap where the finial meets the lid, or even a glue-joint failure. A filet where the two pieces meet might solve the wood movement problem, but would change the smooth appearance.
Re: Pic #2
Toney Robertson
>You guessed it, I used a tenon - 1/2" in diameter and 3/8" long. I then used epoxy for the glue.
Thanks for the nice comments.
Toney
