Granite mini-lathe
Granite mini-lathe
Granite mini-lathe
Eduardo sarmiento-hall
>Hi,has anyone seen or try the steelwork granite mini lathe It seems like a new way in materials to do the work ,hope is not dropped by mistake,lol
Ill get one to try in the near future,Ill get it with-out the motor
ia onlu 1/2 hp Ill put a one hp motor 220 v,and the price seems ok
Re: Granite mini-lathe
Mark Kauder
>I saw one at Highland Hardware a couple of weeks ago, I thought it was really great. I have not turned on one. These lathes are heavy as heck, with a price near that of most mini-lathes, and assuming that you do not want a portable small lathe, I think that one would be a great addition to any shop.
I am told that this same company makes granite TS tops as well.
Mark
Granite Band saw tables as well
Carole Valentine
>I am wondering if they would chip if you managed to drop something like a hammer on them?
Hi-Jack!
Dave Anderson (PacNW)
>Do you think that the reason all of this granite is showing up as machine parts is that we have exported all of our scrap iron and steel to china?
Makes you go Hmmmmmm?
Re: Hi-Jack!
Jerry Klug
>I am installing a granite tile counter top in the kitchen. Granite is pretty tough and maintains flatness well. The only drawback I can see is if it is flexed. For a mini lathe the bed may be short and stout enough to make torsion a non issue.
By the way just what is the weight difference between Steelcity's granite mini and say a comparable Jet?
The spindle bearings and ease of speed changes would be more important to me than the bed material. The Steelcity TS with the granite saw seems to be a pretty fair price. Maybe stone is less expensive to finish than shipping cast iron from the orient, or do they get their granite from China too.
You don't have to "season" granite..
>or wait for the internal stresses to even out.
I remember the first time I traveled the Indiana and Ohio Turnpikes - you saw the cast iron "farms" with all the cast iron engine blanks sitting out in the field.
Re: Granite Band saw tables as well
David Walser
>Yes, they will chip. I looked over a granite bed lathe at the local WoodCraft a few days ago. In addition to the bed, the lathe's headstock is made out of granite. The head stock sported a small chip off one of it's corners. The only advantage I can see for granite over cast iron is granite won't rust. For almost everything else, granite seems to have downsides. While it's possible for iron to break in response to too much vibration, I believe granite would crack sooner (which may be why the lathe's granite bed was MUCH thicker than a similar sized lathe's iron bed). Most of my work lights have magnetic bases and stay in place when I put them on the headstock or the side of the bed. That won't work with granite.
