Delta Midi lathe belt replacement?
Michael Bush
>So I was just now using my small lathe, a Delta Midi, and the headstock made some odd sounds. It turns out the drive belt has shredded into strands. After seven or eight years of use I should be glad to pay $17 plus shipping for a replacement, but I've got to think there is an alternative.
Has anyone replaced this belt with something else, or found a great price on the OEM belt?
Thanks!
Re: Delta Midi lathe belt replacement?
Re: Delta Midi lathe belt replacement? *LINK*
John Peck
>You might try these folks --http://www.beltsforanything.com
Belts for Anything
TomCollins
>John is right. These people are great to work with. I had to replace the belt on my Delta Midi shortly after I started using it. Belts for Anything will probably not be able to look the lathe up directly. I worked with Phyllis Stewart. after several emails she determined I needed a 250J Polyvee. Be sure to tell them how many little ridges are on the inside of the belt. It was a little tight when new but has worked perfectly and is quiet.
TomCollins
Forgot to Mention
TomCollins
>the belt and shipping together was around $8.00 total in late 2007.
TomC
Wilford Bickel
>Just had Joyce at the link shown for Belts for Anything send me 2 for my Delta Midi this past week. She knocked off on the price since I wanted a spare to put up and total was a little over $15 with USPS first class mail. Got them in about 3 days and the first one I put on is better then the one Delta sent on the unit! Now if I had just known a day later the mower deck was going to need a belt in a hurry - oh well - next time I'll order a spare one of those from her and not buy another one from HD in a hurry!!!
