Re: Can't figure this out....
Marc Phillips
>"Are you sure the tenon was large enough in diameter? It sounds like it may have been at the smallest diameter the chuck and jaws would close down on."
It was at the smaller end of the scale... the jaws were nearly closed...
"Anyway, if it is 11" tall and the tenon broke before you could really get started good on hollowing, why don't you just put it between centers again and make another tenon, make this one big enough that the jaws can bite down on it good."
I will ... and the tenon was bottomed out in the chuck too... so apparently a double whammy...
"Was this green wood? It probably got smaller (tenon) as it started drying out."
It is a green piece....
"What chuck and jaws are you using, do you know the upper and lower limits size on them? If not, learn that first and make the tenon in a size that falls in the middle of that range."
It's a Supernova.... and I am going to make some sort of a gauge so I can measure the tenon before I take it off the lathe... I can't tell how many times I have turned the tenon, taken the piece off only to discover that the tenon was too large or too small...
"If it is natural edge, want equipment do you have for finishing the bottom?"
I just use jam chucks for finishing the bottoms...
Thanks Don ....
