1/16 Parting Tool
Woodie49
>Anyone have any information a making a 1/16 Parting Tool ?
Thanks
1/16 Parting Tool
Woodie49
Thanks
I have a small one
steve antonucci
>I made it from an old saw blade. It's only useful for very small parting depth (1/4" or so).
for really small parting cuts I use an xacto craft/hobby saw. Probably cuts 1/64" or so, and it has a "back" so I can use it to about 1" deep (but it will burn if you run the lathe too fast)
Steve
Fillet Knife
Gil Jones...Georgia
>I use an old Rapala fillet knife as a thin parting tool.
Gil
Thanks for the idea!
Re: 1/16 Parting Tool
>I have a paring knife that I use. For really thin cuts I use a drywall saw that I bought at the flea mkt for $1 bran new. I ground off the teeth and ground it to the shape I like. I can go 2" deep with either of these if I open up the cut just a hair.
Barbara Gill, Remlik VA
>I have a great one that someone made from a piece of a broken Wood-Mizer bandsaw blade.
GalenV in Iowa
>I made this 1/16" parting tool from a Titan rigid stainless steel putty knife purchased from Northern Tool for about $5.98 and cut it to shape with a Dremel cutoff wheel. Hard to cut so so it also stays sharp
Works better than the parting tool I bought before.
Threw it on the scanner so picture not that great.
Galen
bill crommett
>I have several made from sawmill bandsaw blades. I will send a piece to anyone wwho will send me his (a generic word) snail mail address. O fcourse you will have to enlist a wood turner or cabinet maker to make a handle for you. To grind the end you are on your own.
Bill
Crommet's Blades :o)
Al Neighbors
>I have one of Bill Crommet's offerings. It's the best little parting tool I've ever used, and stays sharp longer than my converted butcher knife.
Thanks, Bill... you're a gem!
Bill Crommett, email failed...
jwoodwright
>Bill, Hotmail sent a delivery failure... Please email me as I would like some of your blade stock. This has worked in the past when they wouldn't permit an outgoing email... I appreciate this. John Kaner
Re: Bill Crommett, email failed...
Woodie49
>The Same for Me.
Thanks
gil jones................georgia
>Thanks, Bill, below is the response I received when emailing to your address as listed on this post thread.????
Gil
This Message was undeliverable due to the following reason:
Each of the following recipients was rejected by a remote mail server.
The reasons given by the server are included to help you determine why
each recipient was rejected.
Recipient: Reason: User unknown Please reply to
if you feel this message to be in error.
>Also, I have used a sliding T bevel as a thin cutoff tool.
Skip Beardsley------WebKitFormBoundarylsHY4+4w161B
>Since my sawzall box was full of some not so sharp blades I converted a couple to thin parting tools. They come in both long and short versions so I made two handles and have one of each. I can go at least four inches deep with the long one if I an careful and open the kerf just a bit.
One suggestion, use good name brand blades like Lennox or Milwaukee. Box store blades do not work as well.
Skip
Bill Crommett
>try this ; wecrom@nctv.com
Iam having computer problems, but we will keep at it until you can find me. Bill
