Stamping then scraping then waiting - Embossing
charlie belden
>I saw a video of a guy using leather stamps to texture end grain, compressing the wood that was stamped.
A well known furniture maker, Frank Klausz, makes what works essentially like an O-ring seal for a water proof box. He uses a piece of steel wire hammered into the edge of the sides to create a compressed grain groove. He then planes that edge 'til the groove is gone. When water is applied to the edge, the compressed grain swells back to its uncompressed size, rising above the unstamped and planed surface - like an O-Ring.
So - what would happen if you tried that on the compressed/stamped end grain. Stamp it, turn off enough wood to get down to the bottom of the stamped area, then dampen the surface. Would you then get a true embossed pattern (pattern rising above the background as opposed to being down into the background surface)?
