A55 Smoothing Plane
Beall advice sought
Beall advice sought
Beall advice sought
Pete in Holland, MI
>Hey all -
Looking into a Beall system for my bowl work. Have searched the archives and have drawn the following conclusions:
1) Independent wheels verses the all-on-one arbor? Seems the all-on-one arbor is a good idea, but too closely spaced together. Thoughts on either mounting system? Has anyone built their own arbor longer than the stock Beall all-on-one?
2) Appears the 4" ID buffer is the better all-around buffer for bowl work, unless you do really small stuff.
3) Lathe or stand-along motor drive both work well. 1725 motor rpm is the preferred motor speed over the 3450 motors.
4) Light applications of the compounds on the wheels are best. Light touch of the wheel to the bowl is better too.
5) Oil finishes need at least a week to cure in good drying weather to be hard enough to buff & not "flow" during buffing.
Any other advice before I start buying components? I own a JET 1642 lathe, by the way.
Thanx !
Pete
Re: Beall advice sought
>I bought the extension from Don Pencil for my lathe. I love it. I use the 4" wheels and buff on the lathe at about 1000 rpm.
Pete in Holland, MI
>Extension for the inside buffer, I assume ?
>Sorry, I shouldn't have been so vague. I use one of the beal buffer extensions that goes from the lathe spindle to the buffing wheel. I use the 8" extension. go to the link below and click on the Buffing systems and it will show you the extensions.
I'll try again  *LINK*
http://www.donpencil.com/
Roger
>I turned three pieces of wood to around 3"dia x 4"long,put a bolt through the center, to hold the buffing wheel. Mount them in the 4 jaw chuck, one at a time. Works great, wheels don't get in the way of one another.
Russ Fairfield
>My answers to your questions. Others may have different responses.
That depends on what you want to buff. The wheels on the all-in-one are too close together for large bowls, but are excellent for smaller things and pens. The independent wheels can be used for everything.
2) 4" ID buffer
Good for the inside of a bowl, but too small and not flexible enough for the outside. The regular 8" wheels still work best for the outside.
The smaller sheels as they come are too hard to be much good for anything(my opinion). Making 10 or 12 equally placed knife cuts across their surface will make them softer for better buffing.
3) Lathe or stand-along motor drive?
Again, it depends on the size of the wheel. I like to use the 8" wheels at 1000 RPM, and the smaller ones at a faster speed. Having a variable speed makes the lathe the better option for buffing.
4) Light applications and light touch.
Absolutely, and both are easier to do when the wheel is spinning slower.
5) Oil finishes need at least a week to cure.
Not necessarilly. The finish is ready to buff when you get a white powder when buffing it with 0000-steel wool. If you get a gummy residue on the steel wool, it isn't ready to buff.
Pete, I sent you an email...
Al Neighbors
>that contains a pdf file of my homemade system. It's fast, and it works. :o)
Re: Pete, I sent you an email...
Carol - graduation in sight!
>Hey, Al,
Could you slip me an email as well?
Thanks!
Skip Beardsley------WebKitFormBoundarylsHY4+4w161B
>Al,
How about posting a link so others can look at the home made version. I am interested in either buying or making a buffing system. Would also love to know where to purchase supplies.
Skip
Bob Rogne
>Al
Send me the buffing info also.
Thanks Bob R West Mac Turning
Thanx for the advice guys !
Pete in Holland, MI
