Have a question? Ask Woody!
Feathers?
Feathers?
Feathers?
charlie belden
>With all the things people are doing to the outside, and sometimes the inside of a piece, and putting on the outside of a piece - why no actual feathers. There are carved feathers, and pyrographed feathers. And leaves and vines get painted and carved THEN painted, stained or dyed.
Why no feathers?
I'm playing with another Bot Bowl - with the Bot inside - legs pointing up - with fine piano wire on them to extend up above the top of the ginger jar form I'm using. When the lid of the jar is removed, the Bot inside is activated and the extended "legs" will wave around whatever's on their ends. Bought some half drilled 3 mm pearls to stick on the ends along with some drilled crystal beads about the same size, but now I'm thinking feathers. Had an actual feathers feather duster - with some pretty iridescent feathers in it - and some dove feathers off the driveway (doves are really nice to have around).
Nice things about feathers for this application is that while they occupy a lot of visual space, they're light AND flexible. So it the waving legs interfere with each other as they move, nothing can catch.
But wouldn't a pheasant "cape" around the neck of a piece look interesting - if done well?
Re: Feathers?
Re: Feathers?
Don Evans
>It's my opinion that most of the feathers that would be attractive come from species that are on the endangered list. Example would be most raptors.
There are documented cases of (USA ONLY) of Feds coming into galaries and shows and confiscating articles and making arrest. It doesn't matter that you picked the feather up off the ground. American Indians have special rules that they can go by which has to do with religion ceremonies so they can do it but others like me cannot.
It became a really touchy issue few years back and still is in some circles. But as far as I know, A. Indians cannot individually break these laws for their personal gain. But a Chief as example can have and wear his bonnet of eagle feathers in ceremonies.
I'm no expert on this issue and could be off to some degree but I believe I am correct in the overall concept.
Don
Re: Feathers?
Re: Feathers?
John Veerkamp, Western Mo
>Domestic fowl like Peacocks, chickens and Guinnea hens are not protected. You can use their feathers as you wish. There are some quite beautiful feathers in these birds.
Re: Feathers?
Dick Hines
Re: Feathers?
Dick Hines
>You can not use hawk or owl feathers. If you want feathers go to a fly shop. They should have just about any feather you could think of.
Re: Feathers?
Re: Feathers?
Mac
>Pic of a bowl I did in 1998 with feathers......Jungle Cock feathers,we use these in tying salmon flies...sorry about quality of pic,it's an old one...there is nothing new I guess........
Re: Feathers?
Re: Feathers?
charlie belden
>I wasn't suggesting the use the feathers of protected or endangered species. And I am aware, and should have noted, that eagle feathers, hawk feathers, owl feathers and other raptor feathers are, with the exception of native americans, illegal to possess. I'm told, that at least in California, crows are a protected bird, not sure about their feathers.
There are plenty of common wild birds and domestic bird feathers literally laying on the ground all over the place - if you look for them. I've got several neighborhood cats that hunt on my place and I find clumps of dove, robin, sparrow and finch feathers, residue from one of those cat's meals.
I've got a neighbor who has several parrots and pet stores that have parrots might be another source of some colorful feathers - that the birds loose naturally (I'm not suggesting the plucking of live birds).
And chickens can have some pretty interesting feathers, even common domestic chickens, as do the often ubiquitous pidgeon.
Often times, parks with lakes or rivers have a flock of ducks, geese and other birds that might be a source for interesting feathers. Mallard neck feathers can be quite colorful.
The idea of a fly fishing store as a source of interesting feathers sounds interesting.
Imagine a perfectly turned egg - in a nest of down feathers - or a feather lined lidded box - or a lidded box, with a tuft of small feathers in place of, or in conjunction with, a finial. There seems to be plenty of possibilities. Whether they add to, or detract from, the look of a turned piece depends on how they're used.
Some interesting possibilities here somewhere.
Re: Feathers?
You Asked "Why no feathers? "
Barbara Gill, Remlik VA
>Apparently it is not the case. Mac has used them and I am sure if you look hard enough there are more who have.
Re: Feathers?
Re: You Asked "Why no feathers? "
Russ Fairfield
>"The secret to creativity is knowing how to hide your sources." - Albert Einstein
Charlie needs to find more obscure sources for his inspiration.
Re: Feathers?
Mike Stafford
Make your own feathers....
Mike Stafford
>It is fairly simple to make small feather like pieces using "GASP" flat wood techniques. Orienting and choosing the grain properly and doing some overlay sawing with the scroll saw followed by some sanding to thin it out results in a very cool looking wooden feather.
I used to make small ones to decorate jewelry boxes.
Re: Feathers?
Re: Obscure sources of inspiration
charlie belden
>Micro-bots, LEDs, ball and socket joints, glass micro balloons, laser engraving and piercing and piano wire aren't obscure enough already? Perhaps I should return to the San Blas Islands with face mask and fins and search the 300+ square miles of coral reefs for inspiration. An octopus sucker! Or maybe look into tiny shaped charges for piercing AND scortching at the same time. Perhaps a 410 for bird shot texturing - working out range to texture pattern charts and graphs?
Re: Feathers?
Re: Make your own feathers.... *LINK*
charlie belden
>I've used veneer to make wings for a dragon fly. But for the application I have in mind, I need actual feathers. The attached link shows the application - another Wild Hare Idea using a HexBug micro-bot. Feathers won't hang up or snag if there's a conflict between legs.
Bot Ginger Jar Idea
Re: Feathers?
Mike Stafford
Okay. never mind as Rosanna Rosannadanna would say
Mike Stafford
