REAL MILK PAINT
Screws for Nova Chuck Jaws
Jeff Willaford
>Are there any sources for screws for the Nova Chuck jaws other than the Teknatool Jaw Fastening Spares Kit sold by Woodcraft? I know it also includes two hex wrenches and a grub screw but $20.00 ($11.99 plus tax and shipping) for the 8 screws I need is a little salty for my taste. Screw size M6x10 socket screw with 10mm head.
Related question - This is the first jaw change attempt for me and the screws were seized good. The heads... not the threads. Any words of wisdom on how to avoid this in the future?
Re: Screws for Nova Chuck Jaws
>Jeff in the future put a very small amount of Anti Seize compound on the screws. They won't seize up. It's really messy so use a very small amount.
I was able to find screws just like the Nova and Vicmarc at my local Ace hardware. You can also get them from Fastenal.
Don Evans
>Be careful with other screws for this particular application. The one's that I found locally were the right thread and pitch of course but the head diameter was not the same. The screws would not countersink like the originals, in fact they were slightly proud of the hole. What this told me wss the tapered part of the screw may also not be the correct angle. If that is true then vibration will probably make them loosen. After finding this I ordered some from Woodcraft.
Safety is the issue here and may be worth the price.
Don
Jeff Willaford
>Thanks John. I'll check Ace tomorrow. These were factory installed but I'll definitely put a spot of anti-seize on for the future.
Jeff Willaford
>Don, That's the problem I've found. Plenty of 12mm head size but can't seem to find the 10mm size outside Woodcraft (or similar).
Screws for Nova Chuck Jaws can vary
Jerry Hall
>FWIW, I have found variation in the head diameter of Nova screws from different jaw sets. Some were too large to fit down inside Nova long nose jaws without binding. So I had to grind them down to a slightly smaller diameter. So even Nova screws are not "standard" at times.
Walter Ahlgrim
>With regards to your related question, my solution is to buy a chuck for every set jaws I want to use.
If this solution will not work for you the following is my procedure for removing difficult chuck screws.
1 Start with a T shaped Allen wrench NOT an L shaped wrench
2 Do not use a china made wrench
3 If the wrench is not new shorten it on the grinder about 1/8 of an inch
4 At the hardware store get a bottle of �Screw Medic� this is sharp metal filings in cutting oil.
5 Secure the chuck in a bench vice.
6 Clean the Allen socket with dental pick and compressed air.
7 Fill the Allen socket with �Screw Medic�.
8 Insert T wrench seat lightly with small hammer and remove screw.
9 Discard any damaged screw.
Walta
Jeff Willaford
>Thanks to all for the input. Just got off the phone with Tim Geist, Teknatool rep, who was very helpful. I ordered several sets of screws for future insurance.
Don Evans
>What is the price of them from him and how can he be reached?
Thanks
Don
Dick Hines
Dick Hines
>Jeff, get in touch with this guy. He is an authorized warranty and service agent. he will have what you need.
Tim Geist tvgeistmfg@aol.com 304-295-8166
Anti Seize compound
Alex Yeilding
>I'm not familiar with the term. What is it? Plumbers joint compound? Would teflon tape do as well? How about a small amount of oil or grease?
