red oak for a salad bowl?
Steve Kubien
Steve Kubien
>Hey everybody,
I have been commissioned to make a salad bowl out of a particular tree (it has special meaning for the family). I haven't seen it yet and they cannot tell me if it is red oak or white. In the interest of getting my ducks in a row, can I fill the grain of red oak so it can been used for wet stuff like salad? My undertanding is that red oak is porous enough that dressings and wet veggies will ooze through the end-grain.
Also, can you confirm or deny that I will have no such issues with white oak?
Thanks!
Steve Kubien
Re: red oak for a salad bowl?
>Yes, you can "blow bubbles" through red oak. Yes, you can fill (pack) the pores of red oak such that they won't "leak". White oak has pores also - but they are partially filled with material. Note that I said partially. I would want to fill the white oak pores.
YMMV.
Sean Troy
>Two or three coats of Mahoney's walnut oil (wiping excess off after a few minuets with each coat) or Woodcrafts Tung (sp?) Oil, same thing with the wiping after a few minuets and you should have no problems. Depending on your humidity, let it dry for about a week. i've never had any problems with either oak this way.
Steve Kubien
Steve Kubien
>How would you fill the pores? Wet sand with walnut oil or Watco?
Thanks,
Steve
Steve Kubien
Steve Kubien
>Thanks Sean. Good to know.
Steve
Sean Troy
>Finish sanding and then apply the oil of choice with paper towles or cotton cloth. thats all I've ever done with fine results. Make sure to tell the customer never use the bowl in a microwave or dishwasher. It only need be wiped down with a damp slightly soapy dish towls and then wiped with a clen moist towel for rinsing and finish drying with a dry dish towel.
Rick_Allen
>Turn the bowl close to finished thickness and sanded to remove tool marks. Warm the bowl to 120+. and apply epoxy to the warmed inner surface of the bowl until the surface is "wet" (the surface look wet all over). Give the epoxy a day to cure. Sand off all the surface epoxy. Sand and finish the bowl as you like.
jim miles - Charlote NC
>Oak is really bad to split or crack. Get extra wood if you can, just in case.
Brad Vietje
Sure -- just needs more finish oil...
Brad Vietje
>Steve,
I've had good results with Red/Black/Pin Oaks using Urethane Oil and a number of applications. Those pores that allow air &/or water to pass through also allow the polymerizing oils to penetrate, so getting the oil in there is assured. I usually thin the Urethane Oil from Craft Supplies to an 80/20 mix of oil/mineral spirits, and apply 3 - 4 doses, wiping off excess after about 10 minutes the first time, then after 2-3 minutes for each additional application. It will bleed through the end grain for the first few applications, until the holes fill up.
I use the oil straight up for the final application, and rub off any excess so there are no shiny areas. Some people wet sand with Watco, or a similar oil, and fill up some of the pores with the slurry of oil & dust -- that should work fine, but might look dull, and the pores could look too light colored.
Safe spinning,
Brad Vietje
Newbury, VT
