Re: Questions on turning holly.
Emmett Manley, Lakeland, TN------WebKitFormBoundar
>I have enjoyed working with American Holly. Like two other beautiful woods, cherry and dogwood, holly just wants to crack. Most does, some does not. I cannot make a definitive prediction which way it will go. If I had rubbed snake oil on the ends of the pieces that did not warp, I would swear by snake oil. I have never seen the need for expensive sealing solutions, as any decent paint seems to do as well (think about the intended use for exterior paint).
And, most of the bowls I have turned from holly eventually warp, which is not always bad. Some of those blue streaks can be very attractive.
The best way I have found to deal with holly is to throw it in the corner for a year or two, let it crack if it wishes, then cut blanks from the sections not cracked.
American holly is also a beautiful wood to use as a source for white inlays and inserts. Wait until you are sure it is dry, then cut the plugs or inlays.
