how long will green wood be oK to turn?
david e whiting
>I have a cherry treee that fell over during an ice storm in NE. it is 12 in in diameter and I had it cut 3-4 ft long. what do I need to do to keep it from checking so I can turn some bowls ?
tia
dave
Re: how long will green wood be oK to turn?
Barbara Gill, Remlik VA
>Cut the pith out, cover the ends with 2 coats of Anchorseal and the flat with one. Rough turn as soon as possible,
Adrien Coblentz
>Paint the log ends. Use anchorseal if you have it, an oil-based paint will also help keep moisture in. Some folks use paraffin. Keep it out of the weather, especially direct sun. It probably helps if you slice the logs through the pith (lengthwise in the middle) and coat the bare wood. Rough turn as soon as feasible.
Steve Russel's note:
Adrien Coblentz
>http://www.woodturningvideosplus.com/wax-emulsion.html
