BotBowl - finished piece video *LINK*
charlie belden
>Though not a well lit or polished video, you might get a smile out of this one. 800K file so if you're on a slow dial up connection . . .
800K quicktime movie of BotBowl in action
charlie belden
Re: BotBowl - finished piece video
Bill Neddow------WebKitFormBoundary+w+uCg3oRve3I+f
>That is wonderful, Charlie. I am glad you showed the mechanism as well. Where can you get it? I can hardly wait to spring this at one of my wife's dinner parties! (Of course, I will blame you :-))) )
Love it!
Steve Kubien
>Thanks for this Charlie. I'm on new computer now and actually able to see the video. Yup, this is on my to-do list now.
Steve
Where How Much - what's next
charlie belden
>The critter is by HexBug (HexBug.com), purchased at Radio Shack $12.95. Be aware that while the Bot will run for maybe an hour or two unhindered, the run time with sufficient power to move it and a 62 gram bowl on top of it may be only 20 to 30 minutes - max. I imagine a lower gearing would improve that time - but - alas, HexBug has not responded to my inquiry about that possibility.
I think life would have been a lot easier if I'd done the bowl and a separate Bot insert since both are pretty simple to turn.
Now it's on to a piece with the Bot inside - upside down - with piano wire attached to the ends of the legs with turned things on the end - waving around out of the hole at the top of a hollow form.
And I still want to do a hollow form, insert a Bot from the bottom, plug that whole and have the Bot crawl up the wall, slide down and try again, perhaps causing the piece to wobble. Have to figure out how to make interior walls to keep the Bot from falling over. Have a few ideas on how to do that but haven't drawn them up - with How To possibilities for how to turn the parts (it'll be at least three parts).
