The hollow form I was working on...
Marc Phillips
>This is it... from a multi-crotch piece of Sweetgum... literally cut from the intersection of 3 limbs and the trunk... grain was going all over the place (cool!) and there was lots of grain challenges and the spalting made for some extra fun too... sorry to say even after using CA here and there, sanding again, more CA etc. it still cracked...
After reading the responses from my earlier post I now know that leaving it on the lathe contributed to the cracking...
I had lots of successes with this though.... the hollowing started off like a war... just couldn't seem to find the right combination of tool rest height, which cutting tool, which angle to grind the cutting tools, and even which cutting tool to use and when! .... but about 3/4 of the way through the hollowing I finally started getting nice clean passes and some good shavings.
I really want to do hollow forms, so I am going to keep working at it until I at least know what tool to use and where, tool rest height, and on and on...
9" tall, 6" wide at the widest point... 3/8" thick all over, except the very bottom is about 3/4" or so... simply could not get down into the form that deep. I will try using a bowl gouge to get that final bit near the bottom next time.
The sister of this log is going to be in the blank exchange... I have it Anchorsealed and drying...
Anyhoo, here it is... and thanks for looking :)
