>I am doing a ball turning demo on Wednesday so I thought I should practice because I haven't done this in about 6 to 8 years. I was getting pretty frustrated because my balls were not coming out round and a 4" ball was down to 3 before getting it even close.
Then I realized that I had made my cup chucks too shallow. They looked like they were making contact on the outside edge but apparently not. I went back this morning and hollowed them out more and guess what. Round balls.
Just for fun I turned one out of green holly. It will be fun to watch it warp and crack. I will include it in the demo to show what happens to green wood.
Now to go back in the shop and make one out of dry wood.
>I attended Anthony Harris' demo at SWAT last year. I didn't think he used a cup chuck to get them round... I thought they were just to hold them while he turned them. :o)
He cut a shallow groove around the ball one direction, then turned the ball perpendicular (90 deg in the chuck) to the groove, and turned down to the groove, reversed the ball, and did it again. Result - round ones. :)
>I haven't been able to turn much lately. Tuesday I got some green holly so wed. I went in and turned some of it into Christmas ornaments balls to see how it works. Then turned an offset natural edge bowl. Boy does that stuff warp. I'm also having trouble with the tanins in the wood reacting with the tool and leaving green streaks around the bowl. Anyone know how to deal with that. I'm going to try to wipe it out with lemon juice on the next one. It's either that or coat the bevel of the tool with thin CA to see if I can keep the metal contact to a minimum.
I turned a bunch of wine stoppers and then a small cherry bowl. Then today I turned 4 balls. I tossed the first one and hollowed the last one. Both of the Holly balls will probably check. The hollow one already has 2 fairly long long ones even though it's about a fat 1/8" thick. The middle one is Texas Ebony that I've been drying for about 4 years. It's really prone to tear out and was quite challenging to turn into a ball because you could not cut uphill on the grain at all. That required a pull cut here, a push cut there and then finally as I approached the final shape, scraping with the skew. Still had some minor tearout but was able to sand it out with a little 180 grit. I look forward to the final finish on all of these. I have some carved texture in the cherry and I'm thinking about adding some color to the carving.
Right now I'm going to stop and drink more water so I can go on a bike ride. I'm going to put in 30 today. Gotta get rid of this winter tummy. Then I'll turn a pad footed table leg tonight. It's kind of a totally turned cabriole leg in a loose interpretation of that style. That's going to be the demo on Wednesday and I haven't turned one of those in a while either. I'm planning to build a nightstand for my bedroom and wanted to do it with those legs.
>Sounds like you solved your problem John. For others who are having trouble making a round ball, there were two different articles in the March-April 2009 issue of More Woodturning magazine on making balls: "Sphere Template" by David Reed Smith and "Making the Ball for the Chinese Ball" by Fred Holder. Both using different techniques. In the June 2009 issue of More Woodturning there will be another article using another different technique "Turning a Sphere by the Shadow Method" by Terry Scott with pictures by Dick Veitch, both of New Zealand.
Over the last 15 years I've probably turned several hundred balls, many of them 2-1/2" in diameter for the Chinese Ball, of which, I've made over two hundred now. When I was selling at craft fairs I turned them in different sizes and sold them as "worry balls". People had fun handling all of the balls in the large bowl.
>They are just hollowed out pieces of wood. I made one for the chuck and one for the tailstock. Think of it as a sort of cone. You just clamp the wood between them so it can easily be rotated to a new axis.
I turn a rough ball shape and then draw a line around the center. Then rotate this line so it runs between the two cup centers. Now just turn away the shadow. Draw a line and rotate it to a new axis and turn away the shadow. It usually takes about 5 or 6 rotations to get it really round.
