No Finish Finish - Post Lathe Burnishing
charlie belden
>In an ideal world, the finish on a piece would be "from the tool" - the perfect cut burnished by a polished bevel directly behind it.
In the real world
sandpaper followed by sanding sealer followed by some light sanding followed by one, two or twenty applications of a wax or shellac or lacquer or and oil which will harden, with light sanding between applications
often is the finishing schedule for a piece to achieve a semi-gloss surface on the piece.
But if the goal is a burnished wood surface, why not just burnish the wood - with a polished burnishing tool - steel or a hard smooth stone - like say agate.
The Black Pots of Andrews Pueblo's Maria Martinez were given their semi glossy finish by rubbing with polished stones. Works for clay.
Works on at least some woods. I'm using an old jeweler's agate burnishing tool on a redwood lid of a ginger jar. Compressing the grain on the outside of the piece produces a shiny surface - AND - because the grain alternates between soft and hard, the resulting surface has a subtle yet discernable texture you can't see, but can feel.
Have you used burnishing as a finish, and if so, your impressions of the results and any tips you'd care to share,
