Let me break this down a bit...
Marc Phillips
>Things are improving indeed, and I sure appreciate your patience with the questions... From the previous thread I ordered Mahoneys video and hopefully that will help.
I don't have a captured hollowing system... just hand tools.
Sharpening hollowing tools.....
The teardrop shaped cutters.... right now I flatten the back on a diamond stone, then grind with the cutter removed from the tool on the grinder with a 100 grit white stone (Wolverine flat tool rest)
I have the small diamond paddles... and have read that some touch up the cutter with those... how?... the small cutting bevel seems too small to touch up with one of these...
Thanks for the help....
Re: Let me break this down a bit...
>Marc a 100 grit grinder finish should be just fine. I sharpen mine by polishing off the burr using a diamond hone on the top. The I sharpen on the grinder with a 100 grit wheel.
>I think your problem may be using too large a cutter. I prefer a 3/16" or 1/4" cutter for hollowing. I might switch to a larger cutter for the final clean up if you can see and feel inside the vessel. Otherwise I do it all with the 3/16 cutter.
Steve Kubien
Sorry about that
Steve Kubien
>Hey Marc,
When I read you had Randy's Monster tools, I assumed it was his captured rig, not his hand-held tools. Oops.
Steve
