Hollowing help needed...
Marc Phillips
>I would appreciate any and all comments... and tips, hints, help, web sites, good videos, .... anything at all!
I just finished hollowing a 9" deep vase... about 5 inches at the widest point, with a 3" opening at the top with a slightly raised lip.... it started to crack and split, and after using CA it is out soaking in boiled linseed oil.... probably wont make it, but not why I am posting :)
I have Randys Monster Tool hollowing set, which is a long bar and an assortment of cutters... the teardrop shaped one, and some cutters... I also have the Sorby Multitip tool...
So... I shaped the outside, no problem at all... then reverse chucked and used a large forstner bit to hollow out the inside... again, went smooth, no problem.
Here's where I struggle.... using the hollowing tools.
What I am completely unsure about, and having a lot of trouble with is the combination needed with the tool rest height, cutting sequence, and which cutter to use. I somehow make it through until the piece is finally hollow, but it is more like a battle instead of a hollowing exercise.
I did change the grind on the cutters (teardrop shaped) and flattened the back first before grinding on the grinder... and that did help... started getting larger shavings instead of just dust...
I could use some help... any information you would like to give would be appreciated.
