>Contemplating getting a riser block for my Jet 14". Would like to hear how you feel about the ones you have installed, pro and cons. It looks like a nice addition to the capability but I am wondering if the cost is a worthwhile adventure. Would I be better off getting an 18in saw? Thanks, Philip
>I don't have a 14" Jet. I have used a 14" Delta with riser block.
If you feel your Jet has enough power, then go for it. Just don't expect it to be really fast :). IMO, if you are just going for general cutting, then it should work well. For resawing, that would be another matter.
>I have the 14" Jet. LOML bought me the riser this year for my birthday. After putting the riser in it seems that it works much better than it did before. Considering the price for the riser and the cost of a 18" bandsaw I saw it was well worth the money. But then I do not use my bandsaw much.
>I have a 14" Delta. Bought the riser and installed it. Really like it and have resawed a bunch of stuff on it. Not thousands of feet, but dozens of smaller pieces for various furniture projects. Walnut crotches for veneer, side panels for chests, etc. Takes a fresh sharp blade and some patience.
The riser makes sawing turning block much easier.
OTOH, I started with a $600 saw, added a $100 riser, A Carter blade release for $150, Band Rollers ($forgot), Washers to align the wheels ($5), Dust collection ($30) and I am considering a 2 HP motor. It appears it may have been cheaper and easier to buy an 18" saw with those features built in. But, I did not have the money for all that all at once, so I took the kit approach.
If I had the money and the room in my shop, I would have two bandsaws. One with a nice wide blade set up for straight cutting/resawing and the other set up for curves. I hate the changing of the blade and tweaking it takes to switch from bowl blanks to resawing.
>I have the Jet, I agree with Barry's post. I also wish I had more HP. I have all the bells and whistles added too. If I were to do again I would just buy a larger 18" saw to begin with. But I didn't have the money all at once, and put a little money in at a time.
>I took the low budget route with my old Rockwell.
I made the riser block out of 1" square tubing, installed hickory pegs in the corners for the locating dowels, bought a longer bolt for about $8, made a longer blade guard for the rear and used a piece of pipe to extend the reach of the guides. I didn't see the need to extend the blade guard above the guides since I have no reason to put my fingers in that area.
>Thanks, guys. I will evaluate my situation and may just leave it all alone. I will have to check the HP on the motor - -- never thought of that one. Thanks to all! Phil
Go to www.woodturnerruss.com (Russ Fairfield's Site)then to the "Woodturning Stuff" section. He won't steer you wrong. Lots of good info. to help with your decision.
>I have an older (1990 era) Delta with the riser kit. I'm afraid I have to be a bit of a contrarian on this one. The Jet, Delta and others are really not designed to handle the stresses imposed by using a riser kit.
In terms of safety, efficiency and overall ease of use, my opinion is that you would be much better off buying something like a Rikon 18" bandsaw.
On the other hand, now that I have the experience, I would much rather use my chainsaw to process turning blanks as opposed to putting them on the bandsaw. As for getting them round, that's what the lathe is for!
>If you have the money, go for a bigger saw. It would depend on how much you are going to use the extra cutting height. A saw designed to cut 6 inches high with a riser block is pushing the limits of the saw. It can get the job done, but it isn't made for doing that regularly. Having a 1 hp motor is pretty minimal. The second best Christmas present I ever got myself (the best of course was my PM, and then my Robust) was a Laguna 16HD bandsaw. It cuts 16 high and has a 4.5 hp baldor motor on it. This will take care of 90% of my bowl blanks. I now use my chain saw to get the logs into pieces I can lift onto the bandsaw, and do all the other cuting with there. It cuts almost perfectly parallel, and round, so the blanks are a lot more even to start with, and really reduces the roughing out time on a bowl. It won't wake up the neighbors. I never use my electric chainsaw any more. It is also a lot safer than a chainsaw, at least less risky.
>Whether to use a riser block or not depends on how much you will be using it, and how much you are willing to compromise performance and safety.
As woodturners, we are in love with our �riser blocks�, BUT, there is a price for the additional capacity. Besides all of the safety issues with binding and broken blades, inadequate horsepower, and a table the is too small to safely support large blocks of wood; the riser block adds another point of misalignment because there are now two (2) joints in the frame. The additional height also increases the flexibility of the frame and that amplifies any unbalance in the top wheel. In many cases it also restricts the blade width to 3/8" because the taller frame will not support the tension in a 1/2" blade.
If you are using the saw for precision sawing such as �polychromatic� assemblies (a fancy word for �segmented�), DO NOT use the riser block. The saw is capable of smoother and more accurate cuts without it. The closed stand under my Delta would not support the extra height without flexing and vibrating, and that made precision cuts more difficult.
The ocassional user who is not interested in precision can work around, or buy their way out of some of these problems. Adding more HP is an easy option, but it will create some new problems with the next weakest links in the saw. The bearings are too small and the cast aluminum tension block that holds the upper wheel shaft does not have the strength for the additional horsepower. Be prepared to replace them often if you are cutting a lot of large blocks with a larger motor.
I used a souped-up 14" Delta saw for several years. A major overhaul of the saw and replacing the tension block and bearings were a yearly option; and broken and bound blades were a weekly issue with large blocks of green wood.
For any use other than "ocassional", trying to get more out of a 14" saw is a waste of money. It doesn't take much befor you stsrt to approach the cost of an 18" Rikon ($1400) or Jet ($1600). They are built for the job with a larger table that will safely support large pieces of wood, 3 HP, a 12" height capacity, and a 1" blade that will not bind or break. With a 1-1/4" blade, the top guide can be removed to get more height for trimming turning blocks, but you will have to cut a little slower without the thrust bearing. .
I happen to like the Rikon because it does the job and the price is right; but there are others for the same or more money and a different color.
>I have a 14" delta with the riser block. Maybe I don't force it but I think mine works just fine. I've been able to cut full depth green pieces using a $6 1/2" tool blade with no problems. My only real complaint is the table is too small for large bowls but my hollow pieces are usually only 6 to 12" in diameter and it handles those quite easily.
It's not real accurate on resawing but then I don't have a good quality resaw blade either.
>The Jet 14" bandsaw has a 1HP motor. I have a riser block on my jet. I like it. Most everything I cut is wet turning wood. There are two things I don't like. One is that the blade guard does not cover the blade when cutting thin things. I don't care for the blade being exposed like that. The otherthing is all the dust that comes up on the left side. I guess I could solve that problem by installing a brush to remove most of the dust from the bottom wheel.
>I agree with the others who suggested a bigger bandsaw. I got a riser block for my 3/4 horse Delta, and the motor just didn't have the juice to handle it. I finally sold it on Craigslist (with full disclosure), and bought a 14" Rikon. I love it - it's done everything I've asked of it.
>I have a 14" Ridgid w 3/4 hp. It works well if I go slow but I would like to raise it just a couple inches. I am thinking of a couple of 1" shims and a longer bolt, any body see problems with this?
>Won't you have to buy custom blades? Add four inches to whatever they are now and see if they are available in anybody's list. Custom ones are not that hard but could be a PITA if you are in a hurry and may limit your choices.
