spraying lacquer
michael j. neitzel
>What is the best way to spray lacquer?
I have an hvlp spray system and use nitrocellulose lacquer.
Is there a better way than the Grizzley Guitar finish?
Sealer or not? Buffing or not?
Thanks,
Mike
spraying lacquer
michael j. neitzel
Thanks,
Mike
Re: spraying lacquer
Al Neighbors
>Michael, sorry you haven't gotten an answer before now. I've been spraying lacquer for about 20 years now. I use an old, cheap spray gun, with my air pressure set on about 25-30 psi. I use Nitrocellulose Lacquer, Water White, Pre-catalyzed, that I purchase at Munger's in Oklahoma City. (They quit selling it where I live in NW Texas)
I don't use sealer. I always thin like this, in a 1 qt cup: I put in 3/4 oz of Reducer (film canister almost full), 1.25 inch of Thinner, then Fill with Lacquer. (I use the Reducer year round)
I never use anything else in that gun, and have never cleaned it, except about every 3 or 4 months I toss the spray nozzle into a 1/2 pint wide mouth jar of thinner for a few minutes. Sometimes it's 3 or 4 months before I use lacquer, and I just go into my spray room, grab the gun, and go to spraying. Just a quick rub across the nozzle with my finger cleans it off.
That's just the way I do it. Hope it helps a little.
Bill Crommett
>Al: Why the reducer ?
steve worcester
>Reducer is what you would use to thin it out to make it more sprayable. Thinner is for gun cleaning in my opinion.
The other component would be retarder, which is used to lengthen the flash time, or the amount of time for it to flash over. Retarder would be commonly used to allow it to flow better and less orange peel.
As far as buffing, it depends on a few things. The quality of your ,material you are spraying, the quality of gun you are using and how well is it setup, your ability in spraying and what quality of finish you want. All are valid components to the finished product.
For instance, spraying a table top is a lot different that a woodturning.
If you have a true HVLP rig that has a turbine, etc., check with the manufacturer as to what size tip and needle you would need with pre-cat lacquers. The plus side to these are you can get away with a good mask for protection (vs a forced air hood and suit).
If you have an HVLP conversion gun that runs off a standard compressor, then a 1.0-1.3 tip would work fine, and some experimenting to the ideal amount of air and gun setup will get you going.
A good place to start with gun setup is here
http://www.southernpolyurethanes.com/adjusting%20your%20gun.htm
While it deals with polyurethanes, it is pretty much the same.
Change "Reducer" to "Retarder"
Al Neighbors
>My mistake. I use retarder, not reducer. The retarder is to delay the flash time to reduce the chance for blushing. Sorry.
With my cheap gun, I can get a very high quality finish on a table top or a woodturning. I've done both for years. It all comes in the finesse with the gun, and the adjustment of the air/media mixture.
Just my opinion. :O)
Re: Change "Reducer" to "Retarder"
Mark Kauder
>A retarder is used when there is high humidity and high temp to reduce blushing. It has it's place, but it has it's drawbacks.
Adding reducer will retard the entire drying process, not just the initial surface drying time.
If possible it is much better to 1) Control moisture in your air source (turbines heat the are as well), 2) Control the temp and humidity where you store your materials (lacquer and the piece to be sprayed. Temp under 80 degrees (70 is better), but over 50 degrees, and relative humidity under 40%.
I speak only of spraying NC Lacquer, I do not like any other kind with my turnings.
Mark K.
