up grade a nova 3000
richie croce
>like to make my nova 3000 a variable speed lathe. can u do it with out having to buy a new nova dvr?
richie croce
Re: up grade a nova 3000
Ralph
>You should be able to put modify the motor mount and replace it with a conventional EVS motor.
Not saying it would be easy, might just make more sense to replace the lathe (or buy the upgrade package, I do like the DVR-XP I own)
Terry Scott
>Hi Yes the Nova 300o can be up graded In New Zealand we have a firm Motor technologies that supply a motor and the controller for $900 Nz
Our club has 15 lathes 6 we have converted
However 3000S second hand don't come on the market very often and sell reasonably well (as well as a good price ) They are getting $1200 and a new dvr in our money costs $3900.Just bight the bullet and get a new lathe you wont regret it
cheers
Re: up grade a nova 3000 *LINK*
>I upgraded mine by buying a 3 phase motor and Variable Frequency Drive. You do need some wiring skills and it's may have to change some of the program parameters on the VFD so it's not a job for the novice. However you can probably get a good motor repair shop to do it for a reasonable cost.
I purchased mine from http://www.dealerselectric.com/ The first one I did by buying a motor and then finding a VFD. I was lucky and they worked together. They won't always. If you buy a set from the link below the motor and controller will match and work together. I was able to use the controller they sell without changing any of the parameters. There are so many things you can program it's overwhelming and probably best left alone unless your an engineer and know what all these things are.
Long answer but YES
Don Evans
>Hi Richie:
It is still possible to convert the 3000 the way they were done originally. Little history: originally Teknatool shipped the lathes to USA without motors and Woodcraft & others installed the motors that they wanted to offer with the unit. Woodcraft offered this machine with a Leeson DC motor and electronic controller made by Minarik. It gave the lathe, variable speed, reverse and braking capabilities.
I did a little checking at www.surpluscenter.com and they have all the parts needed to do it which consist of:
1 Item 10-2448 Leeson 1hp DC motor $170.00
1 Item 11-2102 Penta controller $160.00 (same controller as the minarik)
In order to give the controller all the bells and whisles you'll also need:
1 Item 11-2102-H Heat Sink $39.95 (mounts on outside back of control)
1 Item 11-2102-S Switch fwd-rev-brk $69.95
1 Item 11-2102-R43 Braking Resistor $4.00
1 Item 11-2102-F46 Fuse $4.00 (I'd purchase couple of spares)
You can go to their site and search on Item numbers and find them.
This is the same set up I had and it had plenty of power but Woodcraft also offered it with a 1.5 HP Leeson also, not really needed.
Now the bad news, you need a special bracket to mount this motor on the side of the head. I don't see why the mount made for the Nova 1642-44 shown on Woodcrafts site would not work. You'll need to check with them to make sure this is a 56C motor mount. If you have the AC motor model now I think that motor mounted on the back of the lathe?
If so, you'll also need another belt but again the one for the 1642 may work. You can call tech support at woodcraft and ask them, if you lathe uses the ribbed pulleys it should work.
You'll also need a little knowledge on working with soldering or a friend that does to install the fwd-rev-brk switch. The resistor and fuse just plug into board. If the motor runs wrong way when switch is in forward just reverse the two wires that go to the motor.
FYI: 1 HP DC motor needs 90 volts DC out of controller, wording on motor makes it look like 180 volts but that isn't correct.
The controller has jumpers to set the input voltage for 120 or 240
and output jumpers for 90 or 180 volts DC.
If you are using 120 volts you MUST set output for 90 volts and it will work correctly with the 1 HP motor.
If you go with a 1.5 or 2 HP motor DC you must have 180 volts DC output and you must use 240 volts AC input.
If you can over come the motor bracket issue then the answer to your question is YES, it can be done.
Don
Re: Long answer but YES
richie
>Don youve gone above & beyond. I cant believe the amount of effert u put into this. Thank you so much, but I dont think I can do all of that!
richie
>thats a very interesting option, I like it.
Stuart Johnson
>I also used Dealers Electric and didn't have any problems. One thing, call them if you have a question. They don't seem to answer email. If I remember right the only thing you need to worry about is the motor mount. Your Nova manual says which you need.
John Peck
>You can find a detailed description of how one woodturner added a variable speed AC drive to a Nova 3000 lathe at this website - http://www.theturnersshop.com Click on "Turning" on the menu and then go to "Tools".
Nova 3000 variable speed motor upgrade
Forgot new motor uses 220 not 110
Stuart Johnson
They do have 110 models
Richie
>John, This all sounds do'able. I have a step pully on the current motor & head stock. What pully should I use?
Don Evans
>Richie:
There is no reason to change the pulley except one possibility.
That is the motor shaft's diameter. In these size motors the shaft's are normally 5/8" diameter.
If your present motor has a 5/8" diameter shaft then just remove the pulley and install it on the new motor (making sure it is 5/8" before purchasing).
Having variable speed doesn't necessarily mean you will not have to move the belt on the pulleys ever again. It will make it less often. It depends on what you are turning.
Don
thanks all for tne help! NM
richie
