Re: It Appears To Be a 4-Piece Laminated...
Frederick Nelson
>Most of these spars (both mast and yard spars) are banded with tight-fitting steel bands. The Bands serve as anchor points for hardware such as lift tackle, brace blocks, and similar hardware for raising sail, or lifting the yards themselves up the masts. The bands are tight and tend to keep checks to a minimum, plus the ends are capped with fitted castings to keep water from soaking into the endgrain, as well as attach hardware.
Once the spar is turned, quite a bit of work remains before it is ready to put into place. Stain and varnish are just the beginning of the finishing process before a mast is stepped or yard put into place.
Fred Nelson
Back from the wilds of Eastern Tennessee to Eastern Missouri
