turning soapstone
patrick stein
>hi everyone, was wondering if anyone has turned soapstone,if so what tools did you use. tryed today and it was very hard to turn with hss tools.
thanks for your time.
patrick stein
turning soapstone
patrick stein
patrick stein
Re: turning soapstone
Don Evans
>Use scrapers only to shape it. Can use other tools for beading or grooves but in a scraping action. No gouges or skews should be used.
Don
Woodie49
>Check out this Stoneturningforum.com All kines of infornation on Soapstone turning.
patrick stein
>thanks sir will try scapers
patrick
patrick stein
>thank you woodie will look at the site
patrick
Dale Cook
>Hi Patrick, I've turned quite a-bit of alabaster and some calsite and recently turned a couple of soapstone pieces. The soapstone is by far the easiest to turn. It cuts beautifully with any type of scraper.I use regular HSS on soapstone. Be careful when parting it off the wood block, as it can be fragile. I put an old blanket or towel on the lathe bed in case it brakes off early. I would leave it an inch and a half thick or so at the tendon and saw the rest off,it saws very easy. Good luck!
Re: turning soapstone *LINK*
Juergen
>Check out Max Krimmel's site he has several tutorials
Technique
patrick stein
>thanks dale I will give the scrapers a try plus a towel my for tears when it cracks. ha
patrick
patrick stein
>thank you juergen
patrick
