Re: Assume the two locations are not close?
Michael Mocho------WebKitFormBoundarygRbxIAUPMcCra
>This may sound crazy, but it really works, as long as you have 3 or 4 alert folks with good balance, and are moving over relatively level ground and shallow ramps:
I have move several full-sized Oneway lathes using only a heavy-duty two-wheeled (vertical style) dolly. The dolly should be stout, and the wheels must be large enough and not too soft. The trick is to slip it under from the headstock side- grabbing the edge of the leg assembly plate, and using a short 2x4 spacer just the width of the dolly under the edge of the steel plate, lift the tailstock end up quite high until the balance point is found. With a person walking on both sides of the tipped-up lathe to help balance it, and the person with the dolly keeping it tilted waaaaay back to keep the center of mass above the wheels, we have moved lathes up ramps, around corners, and through a normal sized door with great success. Letting the lathe down slowly in the new location requires team effort, and blocking the wheels on the dolly so it doesn�t shoot back. Since most of the mass is on the headstock side, the dolly carries the weight without causing hernias on the folks balancing it. It helps to remove the tailstock and tool rest base, and secure the pendant control arm from swinging.
Of course it is essential to have a LARGE two wheeler- not the type used for moving appliances since it must have wheels that are at least 6�-, and several attentive friends to help balance the monster once it is up on the air.
I learned this from Michael Hosaluk, who directed us in the moving several large lathes at the Emma Lake collaborative event. Brains, not muscle.
