A55 Smoothing Plane
Adjusting spindle height
Gary Evans Tallassee, TN
>Hi all,
I've gotten back to using my Woodfast short bed lathe after a long, long hiatus. A friend bought me a copy of David Ellsworth's new book, "Ellsworth on Woodturning" and I started looking at my spindle height compared to his recommendations. He likes the spindle a couple of inches below elbow height for turning bowls and hollow forms. Mine was a few inches above elbow height. I'm just under 5'5"
I built this little platform out of some full cut 2x6's and some 3/4" plywood scraps with a coat of poly to seal. It's not quite as tall as the calculations suggested it should be, but it seems to be high enough. It that turns out not to be the case, I can always raise it more.
This looked to be easier than shortening the lathe stand by 6 or 8 inches. 8^]
BTW, if you haven't seen this latest book by Ellsworth, it's well worth perusing. He talks a lot about the importance of the whole body in providing support and control of the turning tools.
Gary
Re: Adjusting spindle height
Dick Hines
Dick Hines
>Gary, I am glad to see you are back in your shop. I have missed seeing your post.
Hope to see you at the NC Symposium in Oct.
Steven Antonucci
It really makes a difference
Steve antonucci
>If you are turning mostly hollow vessels and follow his methods really helps...
S
