Talking about Peppermills...
Barbara Gill, Remlik VA
>Has anyone used the ceramic peppermill mechanisms?
What is the best mechanisms you all have used? Include ease of fabrication if you don't mind.
Re: Talking about Peppermills...
Steve Kubien
>I really like the Crushgrind with the shaft. It is super smooth in operation and performs like a champ. There are a a couple of more steps involved because of the extra sizes of drill bits but it is not a big deal. My only complaint is that I haven't found anywhere to get them for taller mills.
Prior to using them, I used the Chef Specialties mechanisms. I got mine from John at Woodchuckers or at Lee Valley if he was out. When John stopped carrying them, I switched to the Crushgrind (it was also a moment when I needed to do a matching set for salt and pepper and I wanted to use the same mechanism in each. Kinda of a "planets aligning" sort of thing.)
I hope this helps somewhat.
Steve Kubien
Jim Shaver - Oakville, Ont
>Hi Barb,
I have been making the traditional ones with mechanisms from Chef Specialties for a while. They have been simple to make and always sell well for me.
Now I have been interested in the crush grind mechanisms as well, I have a few and plan to make some to see how the process works, I enjoy seeing some of the design options they enable over the shaft mills.
Hard to beat the old standard, hard to beat the endless options with the crush grind, it's all a matter of taste as I see it!
Be Well,
Jim
david------WebKitFormBoundarylRgnhGioIdOlFg+1
>Barbara: As mentioned below, I use the crush-grind mechanism for the design options. Friend who bought one that I made gave it as a gift to a high-profile Maui chef. His comment to the giver was the mechanism was the best that he has ever used. How about that for a good testimonial! Now if he only liked the design as well...
Thanks Steve, Jim and David
>That is the information I was looking for. Good performance of the grinding mechanism is really important.
Peppermill thread in archives *LINK*
>Barbara,
The link below is to a message I wrote in a thread that discusses this a bit. The photo is of a pair I made with the crushgrind mechanism with the shaft, cocobolo and dogwood. (BTW, the dogwood is actually a rich creamy color, not as light as in the photo.) My wife uses these every day.
We and others have found this mechanism to be very smooth in operation compared to the "traditional" metal mechanisms.
I made some with both the shaft and without. While the mechanism without the shaft gives more design options, I do not like it as much and it's a bit more complicated to construct. If you do go with that, I found that adding an 'o' ring to the stopper makes for a secure fit that is still easy to remove.
You might also check the archives here. There have been other threads on this.
Thanks John. :-)
